Fuel Injector with Broken Tip -- Useless?
  • Stu
    • 4083
    I dropped a ziplock bag with a set of injectors while getting out of the car. One of them landed on the green tip at the nozzle end and the tip broke off.
    This set is useless, isn't it?
    No. You just need another spray tip.
    • Stu
      • 4083
      Jim,
      I know the O-rings and clips are readily available to replace, but I thought the "tip" was considered part of the injector? After some checking, looks like it is. Can't purchase a tip separately anywhere. EDIT: Nevermind, it looks like there are a number of sources for 'pintal caps.'
      Have you ever swapped an injector tip from one to another? Any 'tips' from someone who has a lot more experience than some of us?
      Thanks,
      Stu
      Under Real OEM, I don't see the E36 injector tip available separately:
      http://www.realoem.com/bmw/showparts...69&hg=13&fg=15
      Also, for the E30 (M20 B25) I don't see the tip as available separately:
      http://www.realoem.com/bmw/showparts...67&hg=13&fg=15
      • Luis325
        • 3847
        Where can you buy the tips???
        Have the same problem with my M50 injectors 17.5lbs....2 have broken tips..
        1986 "C2 2.7 Alpina" Sedan
        1987 325ic Black Vert
        • Stu
          • 4083
          I've been told that RC Fuel Injection sells just the tips alone but I havn't verified it. I'm e-mailing them right now and I'll let you know. I'm also in need of 24v injector tips.
          • 416stroker
            • May 2008
            • 2448
            You mean you broke the pintle cap?
            You can buy them on ebay.
            84 318I Delphin RIP
            87 325IS delphin 24v Sold
            89 325 Alpineweiss
            • JGood
              • Jan 2004
              • 7959
              Yep, pintle caps are replaceable.
              Find information, resources and relevant links for lindertech.com. This domain may be for sale.
              Might want to run them under hot water to make them a little pliable, they are easy to break when trying to install them.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • hot karl marx
                • Aug 2009
                • 46
                i broke a few of the little splines off of the tip and mine worked fine..?
                  • 34847
                  you can get new tips at napa.
                  they affect the spray pattern pretty significantly so I wouldn't use broken tips. Plus I think they cost less than a dollar each.
                  • Stu
                    • 4083
                    Looks like RC Fuel Injection sells them for Bosch injectors for around a buck each, won't hurt to pickup spares. Thanks for the heads up.
                    • Tbolt
                      • Nov 2007
                      • 1165
                      where do you see this at?
                      Tbolt Division
                      All I'm saying dude is that bird law in this country...it's not governed by reason.
                      • Stu
                        • 4083
                        Via E-mail from RC:
                        Thank you for choosing R.C. Engineering. Regarding your previous e-mail, you requested pintel caps for your BMW M3 Bosch injector. We definately have an aftermarket cap (baby blue color) in stock for $1.25each. You can place an order by email or telephone. Please include the following information:
                        ~Full Name
                        ~Address
                        ~Telephone number/s
                        ~Item/Size/Quantity
                        ~Year/make/model of car
                        ~For shipping, UPS Nextday, TwoDay, Threeday Air, or Regular Ground (4-5 working days) is available. The cost varies depending on the weight of the package, your preference, and your shipping zipcode.
                        ~For Payment, we accept MASTER,VISA,DISCOVER Card or COD/Money order ($9 UPS c.o.d. charge). For credit card, please include the full name on the card, billing address, billing telephone number, card number, expiration date and CCVC code (last 3 digits on back). For C.O.D/Money Order, we will contact you with the total when ready to be shipped. No personal checks.
                        We will be contact you if we need any additional information or will give you a grand total. If you have any questions, please contact us by telephone for faster assistance.
                        Thank You,
                        R.C. Engineering
                        • 416stroker
                          • May 2008
                          • 2448
                          I always forget about napa
                          84 318I Delphin RIP
                          89 325 Alpineweiss
                          • Tbolt
                            • Nov 2007
                            • 1165
                            I was just at NAPA, not only did they have no clue what I was talking about when they finally found them, they told me they only sell them in a kit with the seals.
                            these are the correct caps right?
                            http://cgi.ebay.com/ebaymotors/BMW-F...Q5fAccessories
                            Tbolt Division
                              • 34847
                              sorry that your napa sucks. When I went there they brought out a whole box of differet caps so we could find the right ones.
                              also if your injectors have broken caps chances are you should be replacing the seals anyway..
