Doin an oil change today ...
  • hamann318is
    • 3382
    Originally posted by nickmp0wer
    how will it hold the synthetic? wont it leak more then normal?
    I changed mine to synth right when I got the car. I checked for leaks. If a leak happens, I'd go to dino oil next time around.
    I haven't had a leak since (I think it's due to the motor's low mileage), and I have continued to use synth oil.
    The BMW 318 is back. With a vengeance.
    • royalflush313
      • Mar 2004
      • 2070
      5w30??
      According to the BMW Manual, 5w30 is intended for Temps -5Celcius and lower.
      Last oil change, 20w50 was poured in the car :shock:
      ~ Go Canucks Go! ~
      • kencopperwheat
        King of Kegstands
        • 14396
        bit thick for canadian winters, not to mention the m42
        Originally posted by Gruelius
        • BavarianBimmer
          • 951
          Originally posted by Mystikal
          Originally posted by DanGillan
          you want something thin for the winter, if yoru using full synthetic, use the BMW synthetic 5w-30, if your not using synthetic, i use castrol gtx 5w-30. it's good for the winter
          Way too thin.
          I use 5w40 or 5w30 winter and summer in my "good old" M10 engine
          it still doesn't use much oil, no leaks visible and runs still fine with +- 200k on the tach
          1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
          1997 E36 328iT
          1990 E30 325iT 24v SOLD
          1989 E30 325i 2.7i M-Technic II SOLD
          • royalflush313
            • Mar 2004
            • 2070
            what would I be compromising if I used a thin oil like 5w30?
            In couple weeks when school is finished, I was gonna go pick up some 10w40 and do my winter oil change, but i think you guys are changing my mind about it.
            AMS Synthetic 5w40 maybe ?
            ~ Go Canucks Go! ~
            • kencopperwheat
              King of Kegstands
              • 14396
              Exactly what I use during the Fall and Winter.
              • Charlie
                kid tested, administrator approved
                • 6686
                http://www.604synthetics.com/products_afl.php
                You're not compromising anything. Run Mobil 1 5w30 synthetic and you will be just fine.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • m42technic
                  • 1056
                  Its funny how everyone thinks lower viscosity oil is the devil...
                  James Peacock
                  WWFSMD?
                  • royalflush313
                    • Mar 2004
                    • 2070
                    I don't.
                    Since I don't know anything, I can only assume that BMW is right, and follow their directions like a little bitch
                    They must have a reason they recommend certain weight oil for certain temperatures though - I'll need to educate myself a little better on the subject.
                    ~ Go Canucks Go! ~
                    • pig4bill
                      • Sep 2004
                      • 122
                      That's because people in much colder climates are recommending it for a guy in Seattle.
                      Check the manufacturer's website. I was going to use Mobil 1 5w30 because Costco had it cheap. But then I checked Mobil's website, and that is too light for my car and climate.
                      • mgold
                        • 709
                        I've been running Castrol GTX or Castrol High Mileage 10w40 for 5 years now. I lose about a quart every 3000 miles. But I also have 163000 miles on my ride. I run Amsoil in the tranny and rear end though.
                        • M-technik-3
                          • 18946
                          Castrol GTX is junk. leaves to many deposits and varnishes. Prefer Valoline over Castrol just about anyday.
                          • M-technik-3
                            • 18946
                            It's not, but is not adequate for protection under high stress loads. But it's perfect for winter condition.
                              • 34839
                              I've tried everything in my E30, but usually I go with 10w30 Valvoline. 160,000 miles and it doesn't burn a drop..
                              5w30 is probably fine for a northwest winter, even on a hot day we'll barely break 80; during the winter it rarely gets above 50.
                              • m42technic
                                • 1056
                                We are talking about synthetics, arent we? All newer BMW engines use 5W-30 synthetic, year round. If its good enough for an N62 in the middle of summer, then I would think it will be ok for my M42 this winter...
                                James Peacock
                                WWFSMD?
