Clutch Replacement
  • yousefi99
    • 9
    Clutch Replacement
    I am installing a new clutch and short shifter in my 85 318i, and I cannot even get the damn transmission out. Do I need to take out the differential or what? I took out every bolt there, but the flex disk is still holding it all up. I need to get the drive shaft out, but I don't know how. Help me soon, the sun is gone.
  • Digitalwave
    is a poseur
    • 6282
    I'm kind of confused. Did you take the flex disc bolts out? If so, unbolt the center support bearing and then fold the driveshaft down, it will pull the flex disc and driveshaft off the tranny, and then you will be able to remove the tranny.
    RISING EDGE
    • yousefi99
      • 9
      I'm going to go mess with it again. I did unbolt all of that, but isn't the drive shaft going through the tranny? I can't move the drive shaft down.
      • Jordan
        • 12911
        Put your tools down and call your local mechanic to tow your car off to his shop.
        https://mtechniqueabs.com/
        • yousefi99
          • 9
          why?
          • Jordan
            • 12911
            why?
            Incompetence.
            • BS87
              • 1606
              Driveshaft is attached to back of transmission with bolts, does not go through it
              • Bill 84 318i
                • 1600
                Gotta pull the driveshaft out, boss.
                It bolts to the back of the tranny.
                • Rigmaster
                  • 3464
                  why?
                  Incompetence.
                  As usual, a very helpful + insightful post.
                  At least the guy is trying to do some of his own work, maybe cut him some slack and TRY to help?
                  Rig.
                  • arnoldgtr
                    • Mar 2004
                    • 153
                    After removing the flex disc bolts, there is something else holding the driveshaft. The transmission flange has a centering pin that is about 1" long. The driveshaft has a hole in the end of it that fits over the pin. You must pull the driveshaft back to clear the pin. Remove the exhaust and the aluminum shield/brace under the tunnel. Then you can unbolt the driveshaft center bearing and drop the center part of the driveshaft. Loosen the sleeve clamp on the center joint of the driveshaft and slide it all the way together. That wiil allow the front of the driveshaft to clear the centering pin. It's best to go ahead and remove the whole driveshaft by removing the four nuts holding it to the differential.
                    Go buy a Bentley and see the light.
                    There is no reason to do jobs like this in the dark.
                    John
                    88 ///M3 Cinnabar
                    84 318i Black
                    • cahomey
                      • Mar 2004
                      • 1201
                      On this board if you arn't some what intelligent, you get rejected...
                      "It's like a koala bear crapped a rainbow in my brain."
                      R.I.P. Harry Goz aka. Captain Murphy
                      "My ride, My ride, she don't beg, steal, cheat, or lie,
                      My ride, My ride, and our relationship is classified."
                      • royalflush313
                        • Mar 2004
                        • 2070
                        kinda like life haha
                        ~ Go Canucks Go! ~
                        • Jordan
                          • 12911
                          Funny how that works.
                          • elemental
                            • Jan 2004
                            • 112
                            when you get to doing the starter here is what I used to get in it
                            The tape keeps the flex joint stiff..
                            dont have too much fun :)
                            • Axxe
                              • Aug 2004
                              • 3355
                              A super-long strait expension will do the job too, so long as you have the tranny as far down as possible (handing onto engine with a jack under the back of it). Also try loosening the collar nut in the middle the driveshaft, that gives you over an inch of play.
                              Keep it slideways!!
