Leaky Coolant Near Throttle
  • llll1l1ll
    • 782
    It's causing me idle pains. Car will idle funny and when I tap the gas, it will stutter and then rev. Also, the exhaust smells bad.
    In any case, I know it's the two hoses that connect to the coolant zone near the throttle body. The top one is leaking all sorts of coolant. However, I want to know why there is coolant in that area!
    Why does coolant flow up there to the throttle body?
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
  • reelizmpro
    • 9558
    Yes it does, so that the coolant can keep the throttle body from icing up in cold climates. If you live in a warm climate, you don't really need it and some even bypass the throttlebody altogether.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • llll1l1ll
      • 782
      O rly?
      I have to get up at the crack of dawn tomorrow before work to fix it so I can get to work. I also live in North Carolina and although it's unreasonably cool for the beginning of September, I can sure as shit expect some drastic heat within five days.
      However, the leak is causing it to idle incorrectly. How would I bypass this without causing a terrible idle?
        That leak isn't the cause of the poor idle. That is a different problem and the most likely suspect would be intake leaks, followed by old plugs, wires, distributor cap and rotor.
        • llll1l1ll
          • 782
          Well, I'll go through and reseal the ICV-ish area with permatex for now. It's all I can do and rather uncouth. I know. Please stop crying.
          It idles near 1200; however, it happened when the coolant leak started. That's why I put two and two together. Also, why I inquired about it, since coolant should have little effect on idle.
          In any case, I should have it all squared away by tomorrow morning... I HOPE.
            • 34844
            I feel like a broken record
              • 34844
              if the leak is causing idle problems it's because it's shorting out your TPS or ICV. check the wiring underneath the TB..
              • llll1l1ll
                • 782
                That's what I thought when I couldn't get to sleep earlier this morning.
                Thanks for letting me bother you guys agian!
