The key wont turn to 2?
  • McGyver
    • 4613
    i have the original key thats 20 years old, so its pretty worn, but it is still able to lock and unlock the doors. i put it in the ignition this morning and it will go from position 0 to 1, but then it wont turn to 2. i also tried pulling the key out, rotating 180 degrees and putting it back in. any ideas of what to do now?
  • StereoInstaller1
    GAS
    • 22679
    get a key cut from the VIN @ dealer.
    Closing SOON!
    Thanks for 10 years of fun!
    • McGyver
      • 4613
      i want to get a new one cut, but it does turn smoothly from 0 to 1, then feels like it's hitting a wall when i try to turn it to 2. does that sound like something in the lock? i had a spring pop out in my buick, but when that happened the thing wouldnt turn at all.
        Since the key will operate the cylinder past the locked position, I'd say that there is a problem with the ignition lock rather than the key.
        • Van Westervelt
          • 9365
          x2 You could try a new key, but my head says ignition cylinder.
          • AndrewBird
            The Mad Scientist
            • 11898
            Try wiggling the key up and down while turning. When keys get too worn, they don't push the pins far enough in. By wiggling and turning, it bumps them into place.
            • dvmotorsports
              • Apr 2008
              • 658
              werd
              Originally posted by jrhaile
              For the record I have never fucked a goat.
              • Van Westervelt
                • 9365
                Also, if you are using the stock key, its is made of steel, and just destroys lock tumblers etc. I always get a brass key made and use it for daily use. I also never unlock my cars from the door as this is typically the most worn lock from all prev owners.
                • dvmotorsports
                  • Apr 2008
                  • 658
                  So how the fuck do you unlock it? Jedi mind trick?
                  • Van Westervelt
                    • 9365
                    Keyless entry, but for a car that doesnt have that yet, ala jedi trunk lock.
                    • dvmotorsports
                      • Apr 2008
                      • 658
                      I see. Never though of that. I have central locking so i'll try that.
                      • McGyver
                        • 4613
                        ok, to the dealership guy told me to take to covers off the steering column and see if its the starter or the lock mechanism that is the problem. i couldnt get the top cover off, but i was able to unplug the orange plug (#3) and can start the car with a screw driver now. so the good news is i can get the windows up, but i still cant get to the top cover off to really get to the steering lock (#4) to try to fix/replace it.
                        • McGyver
                          • 4613
                          Originally posted by McGyver
                          does anyone know how to remove #4 from the housing assembly?
                          • dranttna
                            • 127
                            is your car auto? the nss might be locking the ignition cylinder
                            325es/24v's/20psi/meth injection/
