Wiper washer problems...
  • robert325is
    • Aug 2004
    • 1171
    Well.. i did a quick search and it didn't turn up what i was looking for..
    the problem i have is that when i try to turn on the washers, noting hapeens.. then a few seconds later the wipers come on, but no spray... fluid is full and connections on reservoir are good... any suggestions?
  • jht3
    • 288
    do you hear the pump running?
    James
    '88 M3
    • robert325is
      • Aug 2004
      • 1171
      nope
      • Jordan
        • 12916
        Originally posted by robert325is
        nope
        Then its dead.
        https://mtechniqueabs.com/
          • 34839
          or it could be a fuse, or a relay. could also be a clog somewhere, there's a T fitting that's known to clog up. they're like $5, and new spray nozzles are pretty cheap too
          (mine are all clogged, but since it rains here every day I never need them anyway!)
          • robert325is
            • Aug 2004
            • 1171
            which fuse is it...
            • Axxe
              • Aug 2004
              • 3355
              nope
              Then its dead.
              Helpful as always.
              Rob, I'm not sure which fuse it is, but check to see if you have power at the pump first. Also check the T-fitting that nando said is not plugged, because that can blow the pump (too much back pressure).
              Keep it slideways!!
              • arnoldgtr
                • Mar 2004
                • 153
                If I read you right, the wipers don't come on immediately when you pull the lever for washers?
                I that case, I would check the wiper control relay. It's the long black one in the fuse box. While operating the wiper, remove the fuse box cover and jiggle the relay. The terminals can loosen where they are attached to the circuit board inside the relay. Resolder the terminals, or find another used relay.
                John
                88 ///M3 Cinnabar
                84 318i Black
                • jht3
                  • 288
                  as i understand it, the washers fire for a few seconds, then the wipers turn on to clear off the fluid. that is how its supposed to work
                  in this case the pump isn't running so there's a pause where nothing happens before the wipers turn on.
                  check your fuses first, then check the wiring to the washer pump w/ a multimeter. if you're getting power to the pump but still nothing out of it, check/replace the pump
                  James
                  '88 M3
                  • H&Re30
                    • 242
                    well, how exactly do you take the spray nozzles off of the hood?
