changing my guibo (325i)
  • ///M42 sport
    • 3952
    I plan on doing this over christmas break and was wondering what else I should replace while I'm in there. I already have new tranny mounts, muffler brackets... bolts?
  • DanGillan
    • Mar 2004
    • 4061
    whatever you want, the guibo is like a 15 minute job, it's just 6 bolts off, replace guibo, 6 bolts on, done. tranny mounts are a good idea, as the tranny brace can come off at that point.
    Dan
    • ///M42 sport
      • 3952
      Do I need self locking nuts? Also wondering if its so easy, why shops charge close to $300 for this job?
      • DanGillan
        • Mar 2004
        • 4061
        just re-use your existing nuts, are you sure shops charge that much?
        Dan
        • ryan_george
          • Mar 2004
          • 331
          It was a bit of a pain when I took mine out. Of course I didn't have air tools 8)
          You will most likely need an impact gun to get those bastards off. Also, if you have the harmonic balancer, it make it even more fun :shock:
          • Jared K
            • Sep 2004
            • 58
            Or, you can use a ratchet. Bentley stresses that new self-locking nuts are requred. I just follow directions...
            I replaced the center bearing, all the shifter bushings, the shift lever ( Z3 1.9 lever) & the selector shaft seal in the transmission at the same time as the guibo.
            If for some reason you haven't bought a Bently manual yet, look this over:
            http://www.pelicanparts.com/bmw/tech.../E36-Guibo.htm
            • Jared K
              • Sep 2004
              • 58
              Are you sure about that? 15 minutes? I had to drop the entire exhaust (it's rusted into one piece), remove a heat shield and cross brace & drop the center bearing to get the guibo off. There is a pin in the center of the guibo between the transmission output and the driveshaft. Dropping the center bearling and bending the driveshaft at the universal joint allows you to pull the driveshaft back off the pin. Maybe you are missing that pin? Do you have vibration problems?
              • ///M42 sport
                • 3952
                the harmonic balancer, for the auto tranny?
                shoulda mentioned mines an auto.
                • DanGillan
                  • Mar 2004
                  • 4061
                  OH YEAH!! i forgot the 2 times i did it, we had the whole exhaust dropped already, my bad,
                  Dan
                  • DanGillan
                    • Mar 2004
                    • 4061
                    i found out today, that the book time on a guibo is 3 hours, and at least my shop will give free labor on the center support bearing while the guibo is done, they just pay for the part. and if book time is 3 hours, it gets done in an hour and a half or less 8)
                    Dan
                    • Nihilator
                      • Sep 2004
                      • 21
                      Wow. You did *exactly* what I'm going to be doing in the coming month. Timing belt done, now time to move on to the tranny. Selector seal is leaking bad, so I figured while I was fixing it I'd do the Z3 SSK (with attendant bushings), guibo, and center support bearing.
                      So, any hints? :-)
                      Replacing the exhuast, too, and maybe doing a rebuild kit for the slave cylinder, too, 'cuz it's leaking as well.
                      --Chris
                      • Jared K
                        • Sep 2004
                        • 58
                        2 hints:
                        1) To get the selector seal out of the transmission, push the selector shaft as far as it goes into the transmission (4th gear). That way you will have more clearance to pry out the seal.
                        2) My center bearing was a press fit onto the driveshaft. To get it off, I used a puller with very long arms. To get the new bearing on, I put the bearing in the oven at the minimum temperature (about 150 degrees) for about 10 minutes to expand the metal. Then, I shoved it onto the driveshaft as hard and fast as I could with my hands. It slipped easily into place, then immediatly contracted and locked into place on the driveshaft.
                        Jared
                        • Nihilator
                          • Sep 2004
                          • 21
                          Excellent! Thanks!
                          --Chris
                          • ///M42 sport
                            • 3952
                            anyone know about the harmonic balancer?
                            • Scatman
                              • Aug 2004
                              • 7
                              Think what they're refering to is a metal shroud (of sorts) that surrounds the guibo on some cars. It gets sandwiched between the guibo and output shaft flange on the tranny. Makes getting the bolts out a real PITA since you can't get a wrench on it to keep it from turning... Which is why I paid somebody to replace my blown up transmission - I couldn't get the car up high enough to get the driveshaft out - because of the guibo bolts. I made sure that little sumbitch made it into the 'leftover parts' pile along with my rusted out exhaust. That thing is pure EVIL...
