Stroker problems. Help needed.
  • E30Idea
    • Mar 2007
    • 2196
    So I did the budget eta bottom end 885 head combo with 19lb injectors. I used all "i'' components except the afm (I am using my eta afm just to get the car running). The car idles well, but that is about it. I took it out last night and it drives like shit. After a few attempts to give it some gas and take it over 3k, the car bucks and wants to die. if I take my foot off the gas it will idle out again just fine.
    Could my eta afm be causing this? I dont have an exhaust on it yet (also no o2 sensor), could that be the cause?
    I will take any ideas that you have. TIA
    -Ryan
    ** Lot's of M20 turbo parts for sale.**
    Turn key track car.
    http://www.r3vlimited.com/board/showthread.php?t=222066
    • 34844
    you can't use an eta AFM with "i" electronics. so, that is your problem.
    • E30Idea
      • Mar 2007
      • 2196
      Excellent! Mac brought me one today, so that will get swapped tonight. Thanks Nando.
      Turn key track car.
      • E30Idea
        • Mar 2007
        • 2196
        So I swapped out to an "i" afm and the problem got better. Not fixed, but better. The problem now pertains to more than 20% throttle only. When I try to give it any more than a grandma's foot it bogs down like its flooding, but I dont smell fuel.
        Thoughts?
        Turn key track car.
        • Danny
          • 14216
          O2 hooked up?
          • E30Idea
            • Mar 2007
            • 2196
            Originally posted by Danny
            O2 hooked up?
            It is not yet. Will that play a major roll in our cars?
            Turn key track car.
            • Danny
              • 14216
              It would send it into open loop I believe, someone correct me if I'm wrong.
              • White325is
                • Oct 2006
                • 5947
                What about coolant sensor?? Does it happen when its cold or when it warms up?
                • E30Idea
                  • Mar 2007
                  • 2196
                  Both. I drove the car about 5 miles today. Brought it to full operating temp. Still, anything more than 20% (guess) throttle its starts with its almost missing,flooding feeling. It has also died when I have done this, but as soon as I let off the gas pedal it idles just fine. I have taken it to 4k RPM just fine, but only with a very light foot.
                  I am going to try and get an exhaust on it this weekend and ge tthe o2 hooked up.
                  Turn key track car.
                  • SpecM
                    • Oct 2005
                    • 4531
                    vaccum leak
                    1989 cirrisblau-metallic 325i
                    • White325is
                      • Oct 2006
                      • 5947
                      ^^^ I was thinking about that last night.
                      Start the car and while its running spray starting fluid all over the intake and vac lines.
                      If the idle jumps up then you found your leak.
                      • Devil Inc
                        • Jan 2008
                        • 802
                        Try unplugging the TPS sensor, its only real use is when the O2 is used on our cars.
                        I've been running mine without the O2 and TPS for over a year with no ill effects other than slightly lower MPG.
                        I think a vac leak would cause issues at idle also.
                          • 34844
                          no, the TPS does WAY more than control the O2 sensor (in fact, it has nothing to do with the O2 at all, except for WOT)
                          basically your car is stuck in the cruise map all the time. This means it will run lean at WOT and not have the correct timing, in addition to not using the idle map. It also won't really know when to idle (it still will, it just might be higher/lower than usual and run richer).
                          essentially, your car is much slower than it should be.
                          • E30Idea
                            • Mar 2007
                            • 2196
                            Will this fix itself when I install an exhaust and o2 sensor, Nando?
                            Turn key track car.
                              • 34844
                              I don't know but it can't hurt to have everything there and functioning. Plus with no exhaust it's probably running really lean at high RPM since there's no backpressure at all.
