will it fit?
  • sc26
    • Dec 2004
    • 15
    will it fit?
    hey, i have an 86' 316 e30 and am looking at fitting a new rear spoiler. Would a spoiler for an M3 e30 be too wide for my boot, as i have seen one really cheap. Thanks
  • Digitalwave
    is a poseur
    • 6299
    Won't fit without modification.
    RISING EDGE
    • sc26
      • Dec 2004
      • 15
      ohhhhh damn, how much modification?! is it actually possible?!
      • Digitalwave
        is a poseur
        • 6299
        I am guessing you would have to cut a section out of the middle of the wing or something, and then splice it back together. Anything is possible if you have the money.
        RISING EDGE
          • 37832
          Ya, it's probably not worth the trouble. I know someone makes a replica that actually fits the non ///M cars.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • sc26
            • Dec 2004
            • 15
            oh right, do you know who this company is who makes the replicas??
            • DanGillan
              • Mar 2004
              • 4061
              this isnt entirely true... i have an m3 wing sitting at home, and before i put it away, i held it up to the trunk lid. if i space it evenly, i have about .25-.5 inches of clearance on each side, so essentially if you just drilled through whatever was there i think it COULD be attached, dont know if its the best idea though.
              Dan
              • sc26
                • Dec 2004
                • 15
                oh right, ok, would love to know if anyone has successfully done this as i have managed to pick the wing up for around £25 pounds! i think it is actually a replica kit, so maybe it will fit?!
                • sc26
                  • Dec 2004
                  • 15
                  just to let you know, i got the spoiler and it fit perfectly on my 316! i will post photos soon
                  • uofom3
                    • Jan 2004
                    • 5392
                    fitting a wing made for the e30 m3 to the standard e30 trunk is not something that will fit. generally, you **might** be able to make it fit with some mods... but the wing is not designed for that boot. I would suggest an m-tech 2 spoiler or other aftermarket part that is meant to work the the standard e30 lid... there are a LOT of m3 parts that will go accross to the e30 without change, but the aero takes work that is not always worth it.. plus, i think the mtech2 stuff fits the standard e30 lines better than the wing....
                    cheers,
                    ted
                    PNW Crew
                    90 m3
                    06 m5
                    • mikeedler
                      • 6707
                      if it fit perfectly, it is probably the AC schnitzer EVOIII style wing that is made for the regular E30. I got a great deal on one, and it wouldnt fit my M3.
