320i e30 mods
  • kushesh
    • 55
    320i e30 mods
    Wassup
    what mods can be done to this car in order to beat a 325is?
    thanks
  • mikeedler
    • 6707
    put a 2.5 ltr motor in it and a 4,10. the 2.0 motors are crap.
    • kushesh
      • 55
      if u put a wild cam
      gas flow da head
      valves?
      change da pistons conrod crank?
      • mikeedler
        • 6707
        you can do what you want to the motor, and it will still be hindered by the lack of displacement. you can get m20 2.5 motor just about for free, if you do all that work, do it to a 2.5. as far as valves go, you would be putting the 2.5ltr valves in it. the block has a different bore, but im pretty sure the stroke i still the same. the 2.5 has bigger everything, intake, throttle body, and injectors. the wiring harness and all other components will interchange. if it a later model 320 the exhaust manifolds are even the same as well as the exhaust.
        • kushesh
          • 55
          thanks for the help
          • nzer
            • 122
            Rip everything out your car - get some 98 octane gas, If they car is L-Jetronic do a 23 degree timing advance. You will keep up with one for first and a bit of second .. in third the 325 will own you hah.
            I did this when I had my old 320.
            • Rob
              • 8166
              wait, this isnt the 320 with the 2.0 s14 is it?
              BEERTECH
              • E30godz
                • 1524
                in italy yes, they did make a 2 liter M20 in some places
                • Rob
                  • 8166
                  2.0 m20=shitbox
                  2.0 s14=hotness
                  I would think.
                  BEERTECH
                  • Stu Mc
                    • 4083
                    no rob, its the euro car. it has a 2.0 small-six. 66mm stroke, 80mm bore. small bore head, short rods--not a screamer m20.
                    kushesh, you'll need to bore your block and fit 325i 84mm pistons or aftermarket 85mm. You will need to run 135mm 325i rods and a 75mm or 81mm stroke crank, plus a big-port 'i' head and all fuel injection components.
                    edit: or you can try just throwing a schrick 336 and big-port head in your 2.0 motor, with the right tuning, a fucking light car, and good gear selection, you'll probably stand a chance to a 325i.
                    • MichaelH
                      • 288
                      All that work and your car is still slow....
                      • bmwannabe
                        • 900
                        "theres no replacement for displacement"
                        unless you're FI
                        • Stu Mc
                          • 4083
                          Remember that a 320i is probably as light or lighter than your 318is. With a full 2.5 driveline, it would be damn quick.
                          Boost it
                          • MichaelH
                            • 288
                            Boost it
                            Hey, I never said the 318is was fast! It is actually pretty damn slow. If your goal is to be as fast as a 325i, just buy one. After all that work on a 320 you will probably have more into the car than the $2500 needed to buy a 325i...
                            • bmwannabe
                              • 900
                              M50 or stroked M20 would be good for daily use, seems like FI is a huge hassle unless you have all the tools for tuning. I would get sometihng with more daily useable TQ, (i.e. something NA)
