estimated time to do a timing belt/waterpump
  • natorious
    • 672
    anyone got an estimate on the time to do the job.. i will be doing it in a friends shop but just wanted to get an estimate of how much time i need... im pretty mechanically inclined and he will be there to lend a hand if needed..
    last time i did a timing belt was on my corrado but that is just about the easiest timing belt to swap out that you can imagine...
    anything i should look out for
    doing timing belt, cap and rotor, water pump, and tensioner
  • ///M42 sport
    • 3952
    I would say about 4-6hrs if you know exactly what your doing.
    • egk2
      • 2426
      4-6hrs if you don't know exactly what you're doing.
      • BahnE30
        • 1050
        first time i ever worked on an E30 and it took me about 4 hours to do this
        timing belt / tenisoner, all new belts and thermostat..
        if you've got lots of time take the rad off and hood, makes things much easier and plus give you a chance to flush the entire cooling system out and put all new fluid in..
        helpful writes on there on just about everything E30
          • 34839
          haha, I was going to say 2 hours at the most if you know what you're doing.
          it's not hard at all, it seems intimidating but there's really not much to it, just follow the steps in the Bentley and you'll be fine. One of the reasons I love working on E30s is because most things are pretty intuitive to take apart and reassemble. BTW, might be a good time to replace your hoses if they're really old, and your belts too (since the coolant is drained and you have to take the belts off anyway..)
          • NORCAL/E30
            • Dec 2004
            • 258
            Not to thread jack :? but should I be doing this soon? The timing belt on my car was done @ 65K, car now has 112K.
            ABE
            • natorious
              • 672
              general rule of thumb is about 60k or 4 years for an e30 (or so i have heard)
              • Jordan
                • 12913
                If you drive like a grandma. I wouldn't go over 40k on a t-belt the way most of us drive.
                Chapel took 13hours to do it his first time
                https://mtechniqueabs.com/
                • Rich V
                  • Oct 2004
                  • 69
                  ABE
                  You my friend, are on borrowed time. :shock:
                  • NORCAL/E30
                    • Dec 2004
                    • 258
                    Looks like I'm doing a timing belt!!! :shock: I too, will probably be in the thirteen hour range. :oops:
                    ABE
