Neutral saftey switch harness, will I need it?
  • mcgrath
    • May 2004
    • 445
    Since my 318i is manual and the 325e engine that is going in it is automatic, will I still need to get the neutral saftey switch harness from the 325 or will the car start without it?
  • rs4pro3
    • 5808
    I'd think so
    85 325e 2.7 ITB'd stroker
    • mcgrath
      • May 2004
      • 445
      You think i would need it or do you think it will start without it?
      Thanks,
      Steven
      • rs4pro3
        • 5808
        you'll probally need it, unless you bridge the two wires so the ecu thinks it's in park all the time.
        • mcgrath
          • May 2004
          • 445
          ok, i'll finish pulling it out just to be safe.
          • Digitalwave
            is a poseur
            • 6293
            You are doing an automatic conversion? Why?
            RISING EDGE
            • mcgrath
              • May 2004
              • 445
              The engine in my 318 is going bad from water in the oil. I have a complete 325e engine and driveline, but the tranny is automatic. I can't afford a five speed tranny right now and this is the only car I own so i gotta go with the auto gear box for now :(
              • mcgrath
                • May 2004
                • 445
                I pulled the harness for the auto shifter. looks mostly plug and play so i'm good to go now. just gotta figure out the c101 and the wiring should be over with for the major part.
                • mcgrath
                  • May 2004
                  • 445
                  Just to let anyone know. you do not need the safety harness to start the car. you need the part for power to the light on the shifter and the revers light plug thats it. If you are putting an auto tranny in a car that had a five speed like my sorry ass.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    I take it a 318 tranny will not bolt up to a 325 engine?
                    • AdamF 88iS
                      • 2051
                      Bolt pattern for the bellhousing is different.
                      Adam Fogg- '88 M3
                      Common sense- It's the new 'gifted'
                      • mcgrath
                        • May 2004
                        • 445
                        yeah it won't bolt up. I plan to put a 5 speed in the car but it will be awhile before a can get the funds for it.
