Electric Windows
  • E30-323ti
    • 328
    Electric Windows
    The other day I was fiddling with the centre console, unplued everything etc.. and put it all back together.
    BUT, now when the car is off and the drivers door open I can't control the windows or sunroof (to close them for example), which I use to be able to.
    Any Ideas?? Is there a control box or something that may have blown??
    TIA
    292rwhp E30 :D
  • DaN
    • 1265
    The windows arent supposed to work with the ignition off.
    • e9nine
      • 1890
      Some cars do that... it's possible his car does that? :?
      • DaN
        • 1265
        I've never came across one that did, e30 or others. Unless of course it's wired up to do that.
          • 34839
          turn the key to the "on" posistion but don't start the car.. then you can control your windows. ;)
          • E30-323ti
            • 328
            The windows use to work with the car off & when the drivers door is opened.
            292rwhp E30 :D
            • DaN
              • 1265
              Do they work with the ignition on?
              • E30-323ti
                • 328
                Yip.
                Just a pain in the ass when you get out and forgot to close a window, or the sunroof.
                'Cause sticking the key back in and turning it on is so time consuming, call me lazy, but I like the luxury features!!
                292rwhp E30 :D
                • Bryson
                  • 1490
                  do you have an aftermarket alarm? if so, check all the wiring going in/out of it to make sure everything works
                  • petone
                    • Sep 2004
                    • 4
                    I thought all E30's windows worked when the drivers door was opened, even with the ignition off, real handy when you forget to close a winow or sunroof.
                    • DSchultz325e
                      • Aug 2004
                      • 1158
                      On my gf's E36 they work until one of the doors is opened. I've never seen nor see a reason why you'd want your power windows to function with the car off and locked.
                      I retired my E30 for now...
                      E46 323i
                      David Schultz
