Extra 0.5-1" drop?
  • PeaveyBassist
    • Sep 2004
    • 3511
    Extra 0.5-1" drop?
    Right now I have H&R Sport Springs on my '90 325i with Bilstein shocks and everything else stock. The back is ok, but I want to lower the front about 0.5-1.0" more. Is there a way to do this without buying new springs/coilovers? Would getting camber plates lower the front a little? Or would it stay the same?
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Omaliyo
    • 243
    Same question i have.......
    I have spring pads in but dont know if it would be worth taking them out....
    Or how about some spring perches or something.....
    Slamburglars Handbook:
    5. Slamburglars don't get stuck on speed bumps, speed bumps get stuck on Slamburglars
    • IRON-E
      • 16548
      +3 on the OPs question
      @IRON-E30 aka Edwin:D
        • 34839
        good camber plates (like vorshlag or GC) will lower the front, yes.
        • PeaveyBassist
          • Sep 2004
          • 3511
          like not kmac or something? if thats the case, you might as well just get coilovers. I'm looking for something cheap here.
          DaveCN = Old Man
          • Omaliyo
            • 243
            No thinner spring perches???? top hats???
            • E30SPDFRK
              • 5707
              Camber plates only lower about half in inch with stock diameter springs though. Combined with spring pad removal this will make it noticeably better, but still not even.
              Byron
              Leichtbau
              • Jean
                • 18228
                With the front springs, you could just cut a dead coil?
                • Spaz
                  Crazy Canuck
                  • 2276
                  I've heard of drop hats, and pelican apparently carries them, but i couldn't find them :(
                  Cam .W '91 325is
                  Spaz's 1991 Alpine White???? S52 Build Thread...
                  • Philo
                    Ich esse kleine Kinder
                    • 3334
                    Dead coil story is crap. DO NOT cut the coils. There are numerous reasons not to, and it DOES effect the ride.
                    GC plates will cost $300 and take you down 12mm. If you are looking for a less expensive alternative, you can make drop hats. It is not difficult. There is not a company who makes drop hats for our cars (at least not anywhere near quality).
                    -tim
                    Originally posted by Jordan
                    I like the stance
                    • namsayin
                      • 1568
                      GC's drop 7/8"
                      • daniel
                        • 6703
                        heeeeeere we go again. not that i side with one belief or the other as i have no experience with cutting springs, but...
                        http://instagram.com/dslovn.drives
                        • Jean
                          • 18228
                          Right. and drop hats don't? Everything does a number on ride/handling, from the weight of the car to the height and tires/air in your tires etc ;)
                          • mikeedler
                            • 6707
                            dropped hats would be the only "real" way to go- you could lower the spring perch- but thats alot of work to do.
                              • 34839
                              drop hats give you more but at the cost of suspension travel. IMO camber plates are the way to go, no real drawbacks other than maybe slightly stiffer, which is probably a good thing anyway.
