Steering Wheel shaking
  • PeaveyBassist
    • Sep 2004
    • 3511
    I drove a friend's 91 325i I am looking to buy. Pretty positive I am gonna get it. One problem with it is that when you brake in the middle, not hard or light, the steering wheel shakes. We're pretty sure its warped rotors. Is that what all you guys think it is? My brother said he is almost certain thats what it is. If thats the only problem I am definitely getting it.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Jordan
    • 12916
    could very well (and is more likely) the CAB's
    https://mtechniqueabs.com/
    • PeaveyBassist
      • Sep 2004
      • 3511
      How time consuming is it to change CAB's? How much do CAB's cost?
      Will
      DaveCN = Old Man
      • kansas-ix
        • Jan 2004
        • 1600
        $80 and hour or two keep in mind you need a press to put the new bushing on so some shop time might be added to my est. and factor in an hour or two.
        My bet is on the rotors though, but if it is a new car to you why not do both anyways.
        E30 325ix 62k
        • PeaveyBassist
          • Sep 2004
          • 3511
          I wont do both at the same time because of the cost. I have to save a little at a time to fix stuff like that. And the first thing I am doing to the car are things like that. :) Making sure its in perfect mechanical condition.
          Will
          DaveCN = Old Man
          • Digitalwave
            is a poseur
            • 6299
            Will
            Dude, you don't do shit like that one side at a time. If you can't afford to buy a pair of CABs then you shouldn't be driving an E30.
            RISING EDGE
            • kansas-ix
              • Jan 2004
              • 1600
              then start by having the rotors turned and see what that does,when my CAB's were toast a moderately hard stop the last 5mph of which would make the ABS go crazy trying to stop the car when it was unnecc. b/c the wheel was moving slightly just a tip to see if it is your CAB's better yet when you get the car take a pic of them and post it on here, we'll tell you.
              E30 325ix 62k
              • PeaveyBassist
                • Sep 2004
                • 3511
                Will
                No no no, I meant I would buy CAB's first and have rotors wait. Then 2 weeks later get new rotors. Not one side at a time. lol
                Will
                DaveCN = Old Man
                • Digitalwave
                  is a poseur
                  • 6299
                  Will
                  Will
                  Oh well in that case, do the rotors first. If you do the CABs and then you still have warped rotors, you might put unnecessary wear and tear on the new CABs.
                  RISING EDGE
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    Ok, Rotors will come first then. ATE rotors from Ireland Engineering good? Or Borlo or something like that? If they are both solid rotors, would I really notice that much of a difference? Also, what about Zimmerman cross drilled rotors?
                    Will
                    DaveCN = Old Man
                    • Digitalwave
                      is a poseur
                      • 6299
                      Will
                      If you want slotted rotors you could go with the ATE's. I personally run the OEM solid Brembo's, and they have been great. I have heard good things about Balos as well.
                      Cross drilled are unnecessary for most applications, they cost more, and don't last as long. High bling factor though.
                      RISING EDGE
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        How would http://www.turnermotorsport.com/html...=34111160915CD these be for front?
                        Will
                        DaveCN = Old Man
                        • Digitalwave
                          is a poseur
                          • 6299
                          Is there any reason why you need cross drilled rotors? Just stick with OEM stuff, you can get them for dirt cheap from www.bmaparts.com Brembos are only $30 a piece there, as opposed to $85 a piece for Zimmerman x-drilled, and I doubt you would notice a difference between the two.
                          RISING EDGE
                          • PeaveyBassist
                            • Sep 2004
                            • 3511
                            Mainly just cosmetics. I think they would look cooler :) I'll probably end up getting stock ones anyways for $60/pr.
                            Will
                            DaveCN = Old Man
                            • Digitalwave
                              is a poseur
                              • 6299
                              Will
                              I think they just look poser most of the time. Your car is stock right? Do you still have bottlecaps? You can even see the rotors on those.
                              RISING EDGE
