oil coolers?? worth it or not?
    • 37833
    Adding an oil cooler to any engine is usually a good thing. I say go for it, considering it's fairly simple and can bolt up just like the factory did it.
    Grover Beach, California
    BimmerHeads.com
    • ethrty
      • Nov 2009
      • 342
      i wrecked a B25 and bolted it up to my B20 just because it was there. Didnt make any noticable difference at all. but then with the car being used 90% of the time for 15minutes (albiet hard driving) it probably never got to temp anyway. could see the benifit in a hot climate, but its still hot air going past the cooler
      I say install because you have it, no other reason
      • cobraken
        • Oct 2004
        • 674
        I might put one on as well this weekend but I dont know if I realy want to. My e car runs fine without one, seems like more stuff to have to fk with. I guess it could always be added if needed.
        Randall Racing and Engineering
        Acworth, Georgia, 30101
        http://www.facebook.com/RandallRacingandEngineering
          • 34844
          "hot" is relative. even the hottest places get to like 110-115f. Your oil can easily hit 250-260f, so the "hot" ambient air is still going to cool it down quite a bit.
          but yeah, you'll never warm it up with a 15 minute drive, "hard" driving or not - my oil temp barely starts to move at 15 minutes of street driving.
          • PeaveyBassist
            • Sep 2004
            • 3511
            With my oil cooler, driving in the summer in Indiana in 95 degree temps sitting in traffic, the oil temp will NEVER get above 200 degrees F. I've never seen it get hotter than that. And like Nando said, the oil temp will barely get to 120 degrees after driving for about 10-15 minutes.
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
            • NC325iC
              • Mar 2004
              • 6565
              so here is a relevant question to this discussion, I have an oil cooler tstat on my stroker now, when it was in the car i dont think oil ever went through the cooler (lines were always cold when i checked). Where can i get the oil filter plug (the male-male adapter) that screws into the block. it isnt anywhere on realoem
                If you want to eliminate the oil filter adapter you need part 11112140435
