stupid ? about power antennea
  • Aardy54
    • Oct 2009
    • 55
    Is there a fix for a power antennea unit that continues to run even after the car is shut off and it won't retract but motor keeps running unless I unplug?
    My $$ Pit - 88 325iS
  • StereoInstaller1
    GAS
    • 22679
    Likely a broken drive belt.
    Replace drive belt.
    Good Luck!
    Closing SOON!
    Thanks for 10 years of fun!
    • GANSTA
      • 69
      ^^^^^What he said.
      • browntown
        • Jun 2004
        • 3524
        throw it away and get satellite radio. Put an e36 318i antenna with a stubby top in it's place. reduce the amount of electric gizmos that fail on the car every chance you can.
        • McGyver
          • 4636
          what about an antenna that only goes up some times? power is going to it, but it just doesnt always like to go up...
          • barry
            • 1642
            Viagra
            Needs VIAGRA
            • Black_E30
              • Apr 2008
              • 32
              I just replaced my drive belt with a $3 part from McMaster-Carr. See here for more details: http://www.r3vlimited.com/board/showthread.php?t=155610
              But FWIW, with the belt broken, the motor would only run for a little while after the radio was turned on or shut off. I did not need to unplug it.
              • StereoInstaller1
                GAS
                • 22679
                Your mast was at the end of the travel, his might not be.
                Closing SOON!
                • McGyver
                  • 4636
                  Originally posted by barry
                  Needs VIAGRA
                  thanks, im on it.
