Can I get a pic of how the verts trunk is held up
  • reelop19
    • Jan 2010
    • 770
    I have a coupe and had to remove the springs for my stereo install and need to see how the convertibles have they're trunks held up. Thanks
  • McGyver
    • 4614
    pins on the lid and body in the left side of the trunk go through the holes on each end of the shock and then a little washer slides over the end of the pin to hold the shock in place.
    • McGyver
      • 4614
      • reelop19
        • Jan 2010
        • 770
        Thanks dude. Hey are these parts interchangeable to a coupe?
        • NC325iC
          • Mar 2004
          • 6565
          the hinges are i believe, your problem would be with the lower strut mount i think
          • McGyver
            • 4614
            the lower mount is on the thing that holds the jack in place. the upper mount is on the hinge. you could drill a hole and use bolts with a lock nut, or you could weld the little pins in place. i dont remember what the trunk hinge looks like in a coupe or sedan, so i don t know if those pins are there for you already.
            • NC325iC
              • Mar 2004
              • 6565
              its differnt
              • 87-325ic
                • Apr 2006
                • 1198
                just get some pins and a shock and weld it on. late model verts use two shocks, two weaker ones.
