Ahh - hints on getting the rear main seal in!
  • Sean
    • 5793
    Ok, so, I'm replacing my rear main seal while I'm doing all my work here.
    But, here's my issue. I don't exactly have it in there PERFECTLY straight right now, it's a little off. It's over half way in.
    I rear all the threads, and this should be EASY. I put oil on it and everything, what's my problem?
    the side that's a little higher also has some of the rubber that looks like it's peeling off and sitting on top of the metal - here's a picture of where I got it so far:
    By the looks of the pictures - I wonder how I manage to always make such an supposedly easy task so difficult. God dammit! :evil:
    I think it's bent too...well...fuck.
    Anyone? Answers quick would be awesome...I am so close to being done... :| [/img]
    - Sean Hayes
    • 34847
    I'd try to push the side that's too low back out a bit. you have it pretty cockeyed.
    • Sean
      • 5793
      If I pressed it out, do you think the seal would still be usable?
      I don't want to run ANY risk of having to replace this thing again, anytime soon. :?
      - Sean Hayes
        • 34847
        sure, it's the rubber part you're worried about, not the metal. you shouldn't have to press it all the way out, just enough to get it straight.
        • Sean
          • 5793
          So, really, the rubber INSIDE - the rubber around the crank - is what matters most then?
          So, that rubber flap crap that seems to be peeling off won't matter then?
          I know I may seem repetitive, and I'm sorry if I do. :D
          - Sean Hayes
          • UNHCLL
            • 8790
            installing it from the correct side helps.
            Below the radar...
            • Sean
              • 5793
              Hmm, yep. That would take care of that, wouldn't it?
              I guess my intuition wasn't good enough for this. So, do I need a new seal then?
              Thanks..
              - Sean Hayes
              • UNHCLL
                • 8790
                yes. better to replace now then have to go back and do it all over again later.
                Below the radar...
                • Sean
                  • 5793
                  Yea, now I'll practice with this one. LOL
                  I got it in - any suggestions on how to get it that 1-2 mm further in? I just put it between two blocks of wood, and watched as I compressed it in our vice. is that a good way to go about doing this?
                  - Sean Hayes
                  • UNHCLL
                    • 8790
                    putting it in from the right side should allow it go in perfectly. block and vice is crude, but will probably work. I use a socket the same size as the seal, and tap in lightly with rubber mallet.
                    Below the radar...
                    • Sean
                      • 5793
                      Ohh, I love that idea!
                      What size socket would I need? I have two days to prepare - I could go get one, then return it. :D
                      - Sean Hayes
                      • cheades
                        • 632
                        I found a full roll of electrical tape was about the perfect size as well for tapping the main seal in.
                        • EverWiser
                          • Aug 2004
                          • 313
                          I usually use the old seal to press the new one in...Providing that I didn't t-totally mangle the old one getting it out. Works like a charm...
                          • Sean
                            • 5793
                            Didn't think of that until after I found a roll of masking tape close to the size of the seal and used that.
                            No biggy tho, it's in now - and i'm workin on gettin my new slave and master cylinder on now. So, I'm very close to finally being done with my new clutch! :D
                            - Sean Hayes
                            • Digitalwave
                              is a poseur
                              • 6300
                              Took you long enough :)
                              RISING EDGE
