tachometer question
  • krazykraut
    • Aug 2009
    • 82
    tachometer question
    Where on an M20 does the tachometer read the revolutions? At the crank?
    I have some wires that were cut by the previous owner and cannot tell what they are (this one is blue)*yet color never helps.
    I believe that I am missing a sensor at the crank. I do have the crank positioning sensor, but at the mirror image of it, there is an empty holster.
    • 34844
    at the crank, but the tach in your dash gets it's signal from the ECU
    the other plug is for the impulse sensor, which is used to time the injector firing to the cam. Without it runs in regular alternating fire with no specific timing.
    • krazykraut
      • Aug 2009
      • 82
      Thanks, i was trying to piece it together and figure out this clusterfuk using realoem but just found the sensor
