I hit a pretty nasty pot hole and there was a little bit of an elevated manhole ...
The engine light comes on and I pulled over, oil is pouring out of the oil pan in a steady stream.
I'll be replacing the oil pan, but is there anything that I should check on while I'm in there?
Is there anything else that could break in that process? I mean, are there any sending units, or is the oil pump attached to it?
