Removing 3rd Brake Light in Cabrio
  • aworthybrother
    • May 2007
    • 899
    Hi,
    Requesting help on how do I remove the 3rd brake light from the cabrio trunk lid. I managed to remove the brake light but the wires are soldered in a circuit board. Is there any way to disconnect the wires without cutting them?
    Thanks in advance.
  • idanity
    • Jun 2006
    • 775
    "de-solder"
    are we deleting the light, or just maintenance ?
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
    • Durty Thurty
      • 31
      i just pulled mine off tonight since I am going to be doing a new trunklid. The wires connected on the driver side up behind the panel. I just yanked and the clip came off. I will have a bulb out light im sure but I will cross that bridge when I get there.
      • Dagamus(NM)
        • 618
        Any idea what to do with the wires to get the brake light to go off on the overhead check panel? I wired them all together and it still stays on after I step on the brake. There are four wires, green/red, brown and green/black x2
        Gun control means using both hands
        Sex, Drugs, Rock 'n roll. Pick two.
