WTF, OBC monitor?
  • freeride53
    • 11972
    WTF, OBC monitor?
    Alright, that's it-this thing is driving me nuts.
    Since I got the car, the display had been spitting out erratic digits and shit.
    Last week I read some comments that the problem was because of the wiring being loose. So I popped it out, disconnected, cleaned it, etc.., plugged it back in, and clicked that switch in the back down. So I set the time, and it was working well for a week. It still works, but every now and then, through out the day, it starts spitting random digits, and when I hit, it, it goes back. I took it out, and no matter how many times I take it out, and firmly reconnect the wire, it goes crazy again, and I have to hit it.
    What's the problem? BTW, this is a 6-button, and I just need it for the basics, IE telling the time/temp...until I can afford to spend the extra $$$ on a real one.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • mamzak
    • 883
    Hmm. Sometimes mine goes into like Matrix mode but that's only if it gets really hot, like above thirty. Then I tap it lovingly and it works again...but yeah only in the heat do I have this issue.
    All girls fuck but not all girls fuck around with combustion engines.
    • e34john
      • Apr 2006
      • 3599
      They all do that, don't know what to do about it either. I just push the face in a little and it will fix itself.
      • freeride53
        • 11972
        so, the computer itself, is at fault? or my wiring in the back is faulty?
          • 34844
          common 6 button issue. Mine only did it a few times over the last 8 years though.
          • Sagaris
            • Sep 2009
            • 2243
            Mine does it to, I just tell people its calculating how cool I am.
            • MattM
              • Apr 2009
              • 931
              you can find 13 button ones for ~$50, simple and easy fix :)
              Full Build Thread Here
              • freeride53
                • 11972
                but aren't there extra things needed to be done in order to make it work?
                • MattM
                  • Apr 2009
                  • 931
                  i got my with the entire wiring harness for 50, went from the 2 button clock to obc in about 15 minutes.. IIRC its 2 plugs, one into the cluster, and one to the door beeper. Also the turn stalk needs to be swapped if you want the quick select feature, not required though. I did it for mine, just means removing 2 more screws and another plug.
                  • freeride53
                    • 11972
                    sorry, but please enlighten me- what is quick select?
                    • Mossman
                      • Apr 2006
                      • 1961
                      press turn signal stalk in "towards the wheel" and it changes between modes the OBC is on, pretty cool
                      • freeride53
                        • 11972
                        that is pretty cool :D.
