Engine cuts out while driving......then starts back up by its self
  • kenika65
    • Aug 2007
    • 1336
    uh ya they are cheap and 50cents at a junk yard good place to start!
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • FredK
      • 14761
      Well, the DME is powered from one leg of the main relay. Can you start the car, and tap on the main relay (should be the only one with 5 prongs, if I recall correctly), and get the car to stumble?
      • StereoInstaller1
        GAS
        • 22679
        No, can't be timing...unless you have a funky chip.
        Closing SOON!
        Thanks for 10 years of fun!
        • StereoInstaller1
          GAS
          • 22679
          Yup. Speedo does not come from main relay, so main relay is still your best chance.
          You can test it with 2 paperclips..thunking it will only show an absolutely trashed one, but not like you are describing.
          Closing SOON!
          • FredK
            • 14761
            The long pull was there prior to me changing the timing belt. After I changed the belt, the timing marks matched up.
            • Desaevious
              • Aug 2007
              • 3810
              Some cheap-ass PO must have screwed you over. Find him and kick his ass.
              SC*AR (Schwarz Army)
              • FredK
                • 14761
                Word.
                • nasty50
                  • 36
                  Sorry to hijack your thread but I have a similar problem but mine actually happens if I try to flooor it all the way down in the freway,looses power as if the engine dies but as soon as I let the pedal up it will down shift and come back to life.again sorry its just there's good points here I wanted to see if its related in any ways,help guys.
                  • FLarimer
                    • Dec 2009
                    • 43
                    OP - Just had a similar experience with my e30M3. Driving normal, then dies for a moment and restarts. Freeway and city streets - didn't seem to matter. Traced it to loose solder joints for the Ignition transistor inside the DME. Do you have access to a known, good DME? Try swapping DME's and see if the problem goes away.
                    • nasty50
                      • 36
                      noob here,whats dme?
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        I had a similar problem a couple months ago, the car would cut out for a moment while driving when cold and during cold weather. I figured it was the main relay, turned out the problem was the DME. The problem eventually resulted in the DME frying its injector drivers and the car not starting at all (injectors wide open at all times total flooding of the engine.) New DME and all has been well since.
                        '89 Alpine S52 with goodies
                        • iwantspeed
                          • 3164
                          this
                          this
                          same thing happened to me.
                          I bought the car in december
                          finally fixed it by swapping out the dme
                          I had a similar issue
                          I replaced quite a few things trying to diagnose it.
                          cap
                          rotor
                          plugs
                          I didnt replace the wires but I plan on doing that soon.
                          air filter
                          fuel filter
                          oil change
                          oil filter
                          various vacuum components
                          o2 sensor
                          main relay
                          ecu relay
                          o2 sensor heater relay
                          crank position switch
                          main engine ground strap
                          fuel pump
                          coolant temp sensor(blue base goes to dme)
                          mine was fixed by swapping out the ecu with a stock ecu with a stock chip.
                          I assume there was a cold soder joint, a broken joint or something of that nature.
                          Project
                          Parts for Sale
                          Feedback
                          YouTube Channel
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3594
                            wow, i had problems like this with my m20. so i just changed motors.
                            • Kershaw
                              • 11822
                              the simple fix.
                              AWD > RWD
                              • iwantspeed
                                • 3164
                                it would still have the same problem if you reused the same ecu
                                Project
                                Parts for Sale
                                Feedback
                                YouTube Channel
