weight reduction...
  • DanGillan
    • Mar 2004
    • 4061
    weight reduction...
    i know it's been covered 100 times, but... today i finally got rid of the back seat, trunk tar, antenna, put all the tools in an easily removable container, the total (with tools out) it added up to about 100 pounds. i had the opportunity to corner weight my car at work, and it was 51.4% front 48.6% rear before this weight reduction. so i guess my question is, how can i make the front lighter? i dont want to remove AC as i need it, what other options are there for weight removal on the front end of the car?
    Dan
    • 34847
    take out your headlights, hood and bumper.. that ought to make a big difference.
    • Skafrog
      • 1732
      the motor itself can be very heavy.
      The bumper internals can be heavy. No A/C is fuh raze, and should go with the roll bar nicely :D
      Tube frame the front end.
      Run ellipsoids.
      The valence/bumper is heavy, find a ltw replacement.
      Lose the front subframe.
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
      • DanGillan
        • Mar 2004
        • 4061
        ok... i was being serious, any real help?
        Dan
        • niq_nak
          • Apr 2004
          • 422
          ireland or ma fiberglass hood.
          • royalflush313
            • Mar 2004
            • 2070
            - remove windshiled washer tank
            - CF hood
            - get ellips, and take out the hi-beams
            - no passenger seat (or replace w/lightweight seats), glove box, door panels
            - no fogs
            - lightweight wheels
            ~ Go Canucks Go! ~
            • Old'n'Slow
              • 436
              The question is, why are you doing this? Are you planning on tracking the car? Really, unless you're headed for the track, who cares if you are a percent or two off from perfect? You'll never feel it. AND there are other ways to tune your suspension to achieve neutral handling. If, on the other hand, this is to be a race car, the AC needs to go, as does the power steering. There's probably a hundred pounds right there. Oh, and don't overlook the large weight in the driver's seat. Are YOU as light as you could healthfully be? :D
              • Rob
                • 8166
                bingo. and parking with your employer doesnt count.
                BEERTECH
                • DanGillan
                  • Mar 2004
                  • 4061
                  it is heading to the track, i know this isnt necesary, but it's something i want to do. Power steering definately doesnt have to go, AC would if it ever became not my DD. I am as light as i should be 160lbs. hood is on my "list" but it only shaves what like 20 pounds? as far as ellipsoids, i have smoked ellips, and im not taking out the highs or the fogs, i use those eveyday.
                  Dan
                  • rumatt
                    • Dec 2004
                    • 93
                    I don't see any point in making your car faster until you've done a number of driving schools. You'll screw up all the apex's in the beginning anyway, regardless of whether you've ripped out your AC.
                    For the record, I haven't done a driving school yet myself... but I did send in my registration for my first!!!
                    • DanGillan
                      • Mar 2004
                      • 4061
                      im already registered my man. just something to do in the meantime.
                      Dan
                      • Jordan
                        • 12916
                        Stock hood is ~42lbs.
                        VIS CF hood is ~21lbs
                        CDOC CF hood is <10lbs.
                        https://mtechniqueabs.com/
                        • DanGillan
                          • Mar 2004
                          • 4061
                          thanks
                          Dan
                          • UNHCLL
                            • 8790
                            remove the headlights and HID's
                            give to me in exchange for ultra light sealed beams... I'll even give you the 24 sets of them that i have.
                            Below the radar...
                            • DanGillan
                              • Mar 2004
                              • 4061
                              deal
                              Dan
