Drive-By-Wire BOOSTER (Home Made)
  • Gesucht
    • Nov 2009
    • 100
    The tahoe is stock and only 2 years old, with barely 20k miles on it. Its like not there... when it suppose to be. It gets pretty lame for a moment when you drive up hill, or when you make a quick left turn ( yield on green).
    • george graves
      • 19993
      Really. SO you step on the gas and then there is a lag? Hmmm.... This is a Tahoe you said?
      Originally posted by Matt-B
      • Gesucht
        • Nov 2009
        • 100
        Yes, but i'm not trying to get this tahoe as quick as e30 or other fast car. Just a good reasonable throttle response, not more HP or Torque.
        • raafhimself
          • Dec 2008
          • 451
          Originally posted by NitroRustlerDriver
          That's more than likely the automatic transmission being lame, not the DBW.
          ^ OP read this again. it takes a few moments for the AT to take your throttle command and respond with the appropriate gear change.
          • Gesucht
            • Nov 2009
            • 100
            That makes sense, consider if the throttle response is fine on neutral or park.
            Is there a less expensive way to dial that sensor ?
            • Kershaw
              • 11822
              no.
              and it is not a sensor. it is the transmission.
              AWD > RWD
              • george graves
                • 19993
                ^shut up. It's the sensor. I'm 100% sure of it. I think you should soak it in water and see if it improves it.
                • Danny
                  • 14216
                  Brake clean.
                  • george graves
                    • 19993
                    Honey.
                    • Mossman
                      • Apr 2006
                      • 1961
                      you have to figure out if it's a carbon based or some other kind of sensor. One of them will operate faster in intense heat, the other in intense cold. Just try both, first douse your gas pedal with liquid nitrogen (sneak into local high school science lab and steal it they won't mind), If that doesn't work try the old propane torch. Report back.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        DBW on my brothers 540i/6 is a bitch, laggy as hell when trying to rev match quickly. its the same on my uncles e46m3 when not in sport mode.
                        bmw likely made it that way to make the driving experience smoother and more comfortable, like they did with the clutch valve.
                        • Kershaw
                          • 11822
                          he is talking about an automatic chevy tahoe.
                          WHY he thinks his AUTOMATIC CHEVY TAHOE is a sports car is beyond me.
                          AWD > RWD
                          • Gesucht
                            • Nov 2009
                            • 100
                            Read the actual question (again).:tsk:
                            • Danny
                              • 14216
                              Dude.
                              Brake clean.
                              • Gesucht
                                • Nov 2009
                                • 100
                                You have the exact same answer from these guys:
