cabrio window rattle
  • idanity
    • Jun 2006
    • 775
    my cab is tight.
    no rattles, no noises and just a fun car.
    but, when the top is down, and the windows up, and when i find a bumpy road (i do avoid potholes) i hear the windows rattle on each other.
    does everyone else experience this ?
    i have ensured all my windows are tight (removed interior just for nothing) and just want a cure for this window rattle
    and don't say "roll em down", i do, but my g.f. requests them up most of the time.
    thnks
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
  • thereisnoyun
    • Feb 2007
    • 2301
    I have the same issue, but my only rattle when the top is up, with the window up, otherwise dead silent. sometimes its bothersome sometimes its not.
    • Mossman
      • Apr 2006
      • 1961
      mine do this haven't done anything to try to fix. Subscribing :)
      • McGyver
        • 4614
        i think its inevitable. just compromise and leave your windows down and hers up. works for me!
        • e30rapidic
          • 2167
          there is no fix. You can replace the felt piece on the back of the front glass to deaden some of the noise.
          '87 325ic, powered by S50.
          • Lunner
            • 222
            Had the same problem, told that beezy "either everything's up, including the top, or everythings down. I don't half ass anything."
            Try it some time, it worked for me.
            But on topic, I have the same problem, and the noise gives me irrational (perhaps) fear that one of the windows is gonna crack or something, so I just keep them down.
            But if there's a fix, I'm interested.
            87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
            • Kershaw
              • 11822
              maybe replace the felt with rubber stripping?
              AWD > RWD
              • Tismael711
                • 791
                There has got to be a fix. The verts didnt come from the factory with rattles!
                • Puma
                  • Jul 2011
                  • 93
                  Same problem (windows up rattles). My car is tight too - the only rattles come from the windows when up and the top cover when up. I haven't taken it apart yet to try and identify the problem, but it's driving me nuts as nothing else rattles at all...
                  Proud owner: 1989 325ic
                  • BergerNJ
                    • Oct 2009
                    • 349
                    mine do it too, but also when I close my driver side door the window rattles inside the door.
                    I believe it has something to do with the entire system being worn from old age.
