Where does your temp needle sit when the car is warm ?
  • mjc85
    • Mar 2004
    • 164
    I am just curious to see where other peoples temp needle sits when their car is fully warmed up.
    Mine sits a little bit to the "cold" side of the centre mark. Is this where it is supposed to be ?
    Mitch
    1990 318is Brilliantrot
    • 34844
    that's perfect. mine rarely creeps past the 1/2 mark if i let it sit, otherwise it stays just under it.
    • Jon325i
      • 6934
      On my car ('91 325i), I did a cooling system overhaul in early January and I have deleted the clutch fan, installed the higher setting t-stat and run distilled water with one bottle of Redline WaterWetter. Currently we are in our winter season here in California so the outdoor temps have seldom gone above 65F (20C). As for my cars' operating temp, it stays below the 1/2 mark although it gets close to 1/2 when left idling for several minutes. I'm sure when the warmer weather arrives in the next couple months that will change but I don't expect it to be too much of an issue.
      Where I will get concerned is track day events. By the time summer gets here I want to have installed a Spahl puller cooling fan with a dash mounted switch. That shoud keep the temps in check when I'm exercising the car.
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • rs4pro3
        • 5808
        around 1/4th :roll: Ever since doing the m30 swap it runs cold. Will creap to 1/2 when idiling for a very long time at drivethrews. I'm hoping during the summer it runs warmer.
        85 325e 2.7 ITB'd stroker
        • mjc85
          • Mar 2004
          • 164
          Can't this cause issues ? Maybe your fan clutch is broken ?
          • TimmyBigHands
            • 260
            Mine is low too... sits around 1/4th or LOWER all the time.
            • ///M Powered
              • Jan 2004
              • 1109
              Mine creeps to the middle mark after a long idle as well, and I ahve jsut replaced my water pump. hoses, flushed coolant, new thermostat, etc.
              As soon as I start moving agian it will go down to the 1/4 mark, I'm hoping it stays liek this through the summer.
              • Jordan
                • 12916
                1/4 /w no mechanical fan (no fan at all actually)
                If i sit at idle, and still for ~10 mins or so it will work up to 1/2.
                https://mtechniqueabs.com/
                • tonytony
                  Knee deep in poopie
                  • Jan 2004
                  • 3498
                  mine is just above the blue mark, best check my thermostat :?
                  • kowalski
                    • Jan 2005
                    • 1791
                    mines at a quarter to the middle done that since i rebuilt the head, thermostats prolly stuck open.. o well better hot then cold:)
                    • finch
                      • Oct 2004
                      • 279
                      mine sits right on middle.
                      and frequently goes over.
                      got to 3/4 once..... :oops:
                      • royalflush313
                        • Mar 2004
                        • 2070
                        that's normal.
                        If the thermo was stuck open, the car would stay cool - and if it was stuck closed, you'd know because the car would be overheating.
                        ~ Go Canucks Go! ~
                        • Mot
                          45 toting redneck
                          • 4018
                          exactly half.. creeps just a tad above if i push the car hard.
                          • rs4pro3
                            • 5808
                            I've got an m30 under the hood no room for a stinking Fan clutch :twisted:
                            • hamann318is
                              • 3382
                              Mine sits inbetween 1/4 and 1/2. I've let her idle for a bit, and nothing really changes (maybe nudges closer to 1/2).
                              The BMW 318 is back. With a vengeance.
