e30 Auto transmission upgrade?
  • Ceeker
    • Sep 2009
    • 2821
    ok guys, I know what you're gonna say...LOL. no I don't want to swap a 5 sp in.
    Does anyone know if there is a performance kit or shift kit for e30 auto transmission available? Nothing to hairy; but then again what could be for an auto anyway..lol.
    pm's would be appreciated.
    thanks.
  • StereoInstaller1
    GAS
    • 22679
    When you find something, let me know. I have an M20 E34 I am gonna keep auto, but plan on a tiny turbo...low boost, very laggy, very mellow 200HP is the goal.
    I do NOT wanna change the torque converter unless I have to.
    I am building a cruiser. I wanna drive it to Colorado or beyond, or North Dakota is need be.
    Closing SOON!
    Thanks for 10 years of fun!
    • ja burna
      • Jun 2005
      • 358
      I did this upgrade on my auto.. Higher stall torque converter and modified body.. I had to send the parts in.. http://www.importperformancetrans.com/
      They do e30 transmissions, just search around the site. Costly though..
      "Driving anything else would be uncivilised"
      • blueapplesoda
        • Dec 2005
        • 1904
        I was going to suggest something similar. Auto trans with a different tq converter and different body makes the car so so different.
        • SpecM
          • Oct 2005
          • 4531
          Land Rover Discos used 4hp22 untill the late '90s, lots of the the parts in them are pretty heavy-duty
          just fyi, cuz I don't know if/how if would mount or bolt up
          1989 cirrisblau-metallic 325i
          • M-technik-3
            • 18946
            Todd from TCD did a turbo behind one of his project cars as a mule. Used it for drag racing.
            • StereoInstaller1
              GAS
              • 22679
              Do you have more details of what he did, or should I contact him?
              Closing SOON!
              • Kershaw
                • 11822
                get a sequential transmission. its the ultimate automatic transmission. computer controls the clutch. shifting happens in fractions of a fraction of a second.
                sellholm makes one for e30s. costs around 10 grand. fits without modification into e30s.
                AWD > RWD
                • StereoInstaller1
                  GAS
                  • 22679
                  Great, like I give a fuck. I seriously doubt if I will ever even do a cooler on mine, much less drop 10 large on a goddamn transmission for a stupid E30!
                  Closing SOON!
                  • dreamer420
                    • Sep 2009
                    • 468
                    without spending a shitload of money, what kind of things can you do to them to pep them up a bit?
                    • supernaughtIX
                      • Apr 2007
                      • 260
                      them = auto tranny? if its functioning properly to start with you can modify the valve body(springs?) or buy the kit that is offered in a couple places. You can also try out a different tq converter if you can find one to fit. a lot of volvos and LRs had the same 4hp22 so there might be a good converter out there to change the feel and performance, but since the bellhousings are often different, not all converters will bolt in without modification. If it hasn't been done already, someone needs to sort through some volvos for one that will fit. Maybe something with a higher stall speed? I don't know a lot about tq converters but I would like to know there is a better one for my IX.
                      88 325 IX DiamantSchwarz - TOURING - waiting...
                      89 325 IX AlpinWeiß - Gone
                      88 325 IX DiamantSchwarz - Parted
                      89 325 IX RoyalBlau - Parted
                      88 325 IX RoyalBlau - Gone
                      • Ceeker
                        • Sep 2009
                        • 2821
                        Can someone direct me to a website that sells ZF 4HP22 performance shift kits? I guess I should ask if these are even available? I would like to upgrade and at the same time correct any inherent problems that happen ie.such as slippage.
                        • Ceeker
                          • Sep 2009
                          • 2821
                          I found this on e30techforum:
                          http://cgi.ebay.com/ebaymotors/SUPER...Q5fAccessories
                          Spring kit for the valve body.
                          • supernaughtIX
                            • Apr 2007
                            • 260
                            are you experiencing problems with your trans? depending on the issues a spring kit might not help very much.
                            I found that tightening the bowden cable from the TB to the trans made a big big difference. My trans was making slow, very smooth shifts at low rpms - very blah. after tightening it a bit, it shifts higher and harsher, which is better for me.
                            BTW, check to see if your spring button under your gas pedal is working. Mine was seized and wouldn't let me open the TB past 70% or so. Once I loosened it, wide open was much nicer.
                            • kamotors
                              • Nov 2007
                              • 7102
                              I have a modified valve body and 4.27 torsen diff. and it makes the car plenty fun to drive. still doing a 5 speed swap later but its a blast to drive.
                              7speedshop.com
