100mph shake
  • nickmp0wer
    • 1427
    100mph shake
    my car shakes at about 100mph, any ideas?
  • Tuanies
    • 212
    Get tires that are rated for 100mph+?
    • kowalski
      • Jan 2005
      • 1791
      unbalanced wheels, out of round tires, ball joints and bushings could be bad, low tire pressure, bent somthing?
      • BS87
        • 1606
        Also the fact that your car is shaped like a brick
          • 34839
          solution: don't drive at 100mph...
          • Tuanies
            • 212
            but that would make too much sense!
            • Speed25
              • 39
              My brick is smooth and stable at 130mph.
              • NC325iC
                • Mar 2004
                • 6565
                mine did that before i lowered it. might also be CABs correct me if im stupid.
                • calypso
                  • Sep 2004
                  • 62
                  Mine steering wheel used to shake at 80km/h. Put in some new e36 control arm bushings and now its as good as new. :D
                  • rwh11385
                    lance_entities
                    • 18403
                    Originally posted by NC325iC
                    might also be CABs
                    that was my issue. the control arms were shifting/wobbling, etc.
                    jack up the car so the tire is just touching the ground and try to pull the wheel. see if it moves. if it does, something is wrong. and might be the CABs.
                    • Ryan Stewart
                      I Love Miatas
                      • 8978
                      Yeah it can be many things suspension related. The best thing to do is to start with the wheels/tires. If its not noticeable till 100 then its something small and harmonic. Check balance/round and then move onto suspension. Mine ended up being the rear mounts/bushings. Mine did it about 80mph.
                      BTW, my brick is butter smooth and fairly quiet up to 150.
                      Im now E30less.
                      • DarkWing6
                        • Apr 2004
                        • 7144
                        couldn't it also be a wheel bearing?
                        • kowalski
                          • Jan 2005
                          • 1791
                          yeah it coudl be a wheel bearing but those usualy accompany noises too, and perhaps wheel wobble but its worth checking.
                          • nickmp0wer
                            • 1427
                            yeah im pretty sure one of the wheels move when i try to shake it but ill examine it more spring break
                            • rwh11385
                              lance_entities
                              • 18403
                              CABs or Ball joints. depends on in which way it moves. I think perpendicular to the plane of the wheel well (in / out of it) is CABs. Front/back is ball joints.
                              *i think*
