Hey i have a auto 320i and it wouldnt start without me playing with the shifter. I pulled the shifter apart and found that the 2 wires coming for the shifter were split so it was causing it to think it wasnt in park or neutral. So i was wiring them back together and accidently left the ignition on and shorted the two wires together. Now when i turn the ignition on there is no lights on the dash except for the battery indicator. So im thinking fried ecu or a fuse somewere? any help PLEASEEE
URGENT NEED HELP 320i not starting
yeah i tried that i pulled it and put a freshly charged battery in it and the problem is still there. And yes i had a look at the fuse panel in the lh side of the engine bay and they all seem fine. My car is a japanese import so i dont have a guide to the fuses. Which number fuse should i be looking at? I really need it going as its my only vehicleComment
Fuse 10? It's the main fuse for a lot of important accessories, including the start circuit. Mine kept blowing because the wires for the check engine light (which I had disconnected because I got tired of it being on) were dangling behind the dash and grounding on the ABS unit housing. Taped it up, replaced the fuse, and we're good to go.
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
