E28 3.25Diff LSd will bolt in my e30 Turbo?
  • diegom6
    • 4447
    Originally posted by rs4pro3
    the E28 535is diff has a larger case then all other E28 diffs
    the 533i and 528e diffs are the ones that will fit with the cover and flange swap.
    Well this case you see is from a 528i (not "e"9 cuz is german, and the 533i originall e28/ case is in the old 528i Wich we swapped along with the 3.3L to make the "528i" more power!
    Both swapped directly with out (in both e28s) triming or modifying soemhting....weird thing!
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    • James Crivellone
      Head Janitor
      • 6305
      Originally posted by C ///M
      I have a 3.25lsd from an E28 535is in my e30.
      Ditto, just had to swap rear cover and output flanges
      • pogiboy9
        • 475
        do the e28's all come with LSD ? ... if not what differentials are on them. Also .. is the e28 rotors a direct bolt-on to do a 5 lug conversion to my eta.
        http://www.decal-spec.com
        • pogiboy9
          • 475
          i can just go to the junkyard and find out if it fits, but if i can save the trouble and find out which one is it'd be easier. Thanks guys
          • Matt86es
            • Aug 2004
            • 616
            I don't think that they were all LS, but the ratio should have an S in front of it if it is. Bring something with you to clean the ID plate off with as they are often crusted over.
            A 5-lug swap is never an easy thing, but most people use E30 M3 parts if I'm not mistaken.
            • pogiboy9
              • 475
              Hey matt thanks
