Welding my sunroof shut!!!
  • e30 gangsta
    • 3877
    I hate my sunroof it doesnt work and it blows. You guys have any tips on welding it? Like i wanna weld it then use dura glass and stuff to smooth it out before the respray. Any ideas?
  • ZiMMie
    • Jun 2004
    • 968
    it has been done before. try pmin Felixthecat on maxbimmer.
    www.stancefactory.com
    • kowalski
      • Jan 2005
      • 1791
      unless you'v welded sheet metal before then i dont recomend it, you could either burn a hole in the metal or warp it which is a big pain in the ass but if you have just but weld it together and smooth it out with filler after.
      • Eric
        • 5142
        just make a nice consistent seam weld, that will make it easier to grind the welds flat to get a nice "straight" finish :giggle:
        • BahnE30
          • 1050
          umm except for the fact the excessive heat from welding will cause the roof to distort
          make hundreds of small tack welds until it's sealed up then grind and bondo
          would look this * * * * * * all the way around then just keep going around and around allowing the metal to cool so you don't warp the shit out of everything.
          or just buy a new damn seal.
          • kowalski
            • Jan 2005
            • 1791
            exactly
            • Axxe
              • Aug 2004
              • 3355
              Much easier to get a new seal.
              Keep it slideways!!
              • e30 gangsta
                • 3877
                ok so lets say i do get a new seal then what would i do to get it to fit right. My rails are stuck i belive, they dont move with turning the handle @ least.
                God i hate my sunroof.
                • Dave
                  E30 RAT
                  • 11675
                  Duct tape is your friend. :pimp:
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • rumatt
                    • Dec 2004
                    • 93
                    I was wondering the same damn thing. Sunroofs suck. I don't desire to change the look from the outside, just stop the wind noise and give myself an extra inch of interior headroom. :twisted:
                    I have mild wind noise from the front of the sunroof when going about 75 or higher. Is this normal, or will a new seal make it totally silent? I've already adjusted the hight as described in the Benteley (Front a few millimeters low, back a few millimeters high) and it didn't help.
                    • kowalski
                      • Jan 2005
                      • 1791
                      i dont have any wind noise, so the seal will probably take care of that, neither mine or my friends car does.
                      • Eric
                        • 5142
                        nope this guy is wrong, weld a consistent bead so you make sure you get a good seal, I promise :drink: :giggle:
                        • rumatt
                          • Dec 2004
                          • 93
                          Thanks. I'm going to tape mine up to see if that makes it stop. If so, I'll start looking into a possible new seal. Or, I'll just pour a gallon of superglue into the f*cker. :borg:
                          • kowalski
                            • Jan 2005
                            • 1791
                            haha well good luck:)
                            • hamann318is
                              • 3382
                              Hehe, you guys could just be cool like me and not have a sunroof. ;)
                              The BMW 318 is back. With a vengeance.
