Welding my sunroof shut!!!
    • 34844
    I love the solutions to fixing problems.. haha. sunroof doesn't work. so I'll weld it shut! :rofl:
    your sunroof drain is probably clogged.. the sunroof "seal" is a wind seal, not a water seal. there are little tubes that are supposed to channel the water outside the car.
    maybe you should fix your sunroof.. I live in one of the rainiest areas of the country and mine does not leak a bit. I love my sunroof, and I couldn't imagine not using it if I lived in a warm climate like you do..
    • Erick
      Official R3V Drifter
      • 11169
      It works against us in the summer..... when it's not raining, it fries you. The winter was the best time to use the sunroof. Can't believe it's getting hot here already
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • BahnE30
        • 1050
        Originally posted by Eric
        Originally posted by BahnE30
        umm except for the fact the excessive heat from welding will cause the roof to distort
        make hundreds of small tack welds until it's sealed up then grind and bondo
        would look this * * * * * * all the way around then just keep going around and around allowing the metal to cool so you don't warp the shit out of everything.
        or just buy a new damn seal.
        nope this guy is wrong, weld a consistent bead so you make sure you get a good seal, I promise :drink: :giggle:
        pfft obviously your the one :drink::drink: :D
        • Sean
          • 5793
          Yea, in further detail: Pull back the trunk carpet, and you'll see the little black things on either side with black hoses going to them - those are the sunroof drains.
          - Sean Hayes
          • e30 gangsta
            • 3877
            So how do i unclog them?
            • Sean
              • 5793
              In the bentley it suggested using an old antenna mast, lol
              Anything that is long, bends, and is easy to push. I'm not quite sure of what else.
              - Sean Hayes
              • BMW BMXER
                • 2325
                Coat hangers work.
                Sold it.
                • e30 gangsta
                  • 3877
                  so bascially jam it up the ruber tube in the trunk of the car?
                  • Bryson
                    • 1490
                    you guys do realize that the sunroof seal DOES NOT seal water from the cabin, right?
                    What does is the catch tray that is in back/below the sunroof that attaches to the rails in addition to the 4 drain tubes that run down the a and c pillars. If you are leaking water from the sunroof, the sunroof itself is not your problem. Unless, of course, there is a hole in your sunroof panel
                    edit: didn't read the second page. Your drain rails can be fine but if the drain tray is jacked up then the sunroof will leak as well
                    • e30 gangsta
                      • 3877
                      so how do u unclog everything? just a hanger up threw the big rubber hoses?
                      • jcsomerset
                        • Jan 2005
                        • 17
                        I've had people suggest a piece of coaxial cable.. it's flexible - yet stiff enough to move most of the junk - and should'nt puncture the drain tubes themselves. (assuming you cut the tail off of it before using it)
                        1987 m6 and 1989 325i
                        • Eric
                          • 5142
                          I guess you just didn't get my e-sarcasm... I was hopping that this poor guy would take my advise, then he could become the R3v verison of some of the VWvortex kids
                          but no you had to spoil my plans :evil: j/k
                          • arsevader
                            • May 2005
                            • 1025
                            The seal isn't for sealing out the water...
                            The sunroof seal doesn't actually seal out the water, it's for wind noise only.
                            That's what the sunroof drains are for. If your car leaks then check the drain tubes.
                            The sunroof seals are in 2 pieces and can't make a watertight seal anyways.
                            James
                            guess I should look before opening my big mouth. ;)
                            • e30 gangsta
                              • 3877
                              i threw 4 feet of cable up the tubes still leakes.
                              • BS87
                                • 1606
                                Re: The seal isn't for sealing out the water...
                                James
                                A+ for summarizing what everyone else in the thread said.
