Cleaning cosmoline
    • 37832
    Cleaning cosmoline
    What works best fellas
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
  • Jordan
    • 12916
    gasoline
    https://mtechniqueabs.com/
    • jcsomerset
      • Jan 2005
      • 17
      When I cleaned off my valve cover - I used simple green and a soft wire brush on a drill. (got to be careful with the wire brush app - it can and will remove aluminum.. )
      1987 m6 and 1989 325i
      • Jordan
        • 12916
        Simple green is about as useful as water.
        Use gasoline.
        • jcsomerset
          • Jan 2005
          • 17
          I used water too - (and have had wonderful results using simple green for engine cleaning; it's one hell of a de-greaser)
          Gasoline is volatile; carcinogenic and corrosive -
          If anyone uses gasoline - Wear thick rubber gloves - and a gas mask.
          • Jordan
            • 12916
            Volatile? Yes... but so are most good solvents.
            Carcinogenic? Sure, but who cares?
            Corrosive? Not in any of my experiences.
            I wear jeans, tshirt, and skin. Gloves are for pussies. Why would you use a gas mask?
            jcsomerset = big waffleswaffleswaffleswaffleswaffles.
            • boom-monkey
              • 1104
              True, I've used gas to clean paint of my hands and arms, just wash it off afterwards, it's not like you soak yourself or the engine in it.
              Corrosive!? If it was corrosive you wouldn't have a gas tank much less a fuel system or and engine.
              • jcsomerset
                • Jan 2005
                • 17
                How old are you again?
                At least I get and have had waffleswaffleswaffleswaffleswaffles -
                More than you'll ever get Loser boy-
                Of course - if you're gay then you don't want waffleswaffleswaffleswaffleswaffles..
                Real mature from a site administrator. I bet you have lots of friends
                • jcsomerset
                  • Jan 2005
                  • 17
                  It's corrosive to your skin. Try not washing it off for a while. see what happens.
                  It was neither designed nor should be used as a cleansing agent.
                  I'm done here.
                  • Jordan
                    • 12916
                    I'm done here.
                    Yes, Yes you are.
                    • BS87
                      • 1606
                      It may be carcinogenic, but seriously, by the time you develop cancer from a 1 time useage of it, you'll be rotting in the ground. Common day household items are more carcinogenic that gasoline.
                      • Jon325i
                        • 6934
                        I'm surprised no one has mentioned Castrol SuperClean. Pretty potent stuff....its been able to remove a number of oily/greasy/stubborn residue messes from my undercarriage and engine compartment. For cosmoline it may require some scrubbing effort (Dave Adams' had success with it on his cabrio by using a plastic bristle brush). Haven't attempted cosmoline removal in my car yet. Its got some.....not much though. When using the SuperClean make sure you have some ventilation going of some kind. That stuff is strong.
                        If all else fails, Jordon's gasoline suggestion should work too.
                        Jon
                        Rides...
                        1991 325i - sold :(
                        2004 2WD Frontier King Cab
                        RIP #17 Jules Bianchi
                        • gstuning
                          • 833
                          Check out diesel fuel as well,
                          Gunni
                          @ Prodrive / Aston Martin Racing
                          • ryan_george
                            • Mar 2004
                            • 331
                            I've always found gasoline to be very effective on grease. I had a 2 stroke bike that used to leak oil like a mother. Then dirt would stick to the oil.... you get the idea. Gas has always worked.
                            I've also heard of using diesel, but never tried it. Stinks too much for me.
                            • e30evolution
                              West Werks
                              • 1888
                              if you dont wash your hands after using gasoline for such things your hands will dry out... and your skin will crack.... (over time) it doesnt feel good.... normal latex gloves will not protect from gasoline.... you need to blue nitrile gloves....
                              but yah.... i always wear gloves, i cut and file my fingernails... i even trim my cuticles.... gloves make cleaning up after work soo much easier
                              http://www.westwerksauto.com
