My 1991 M20 has a Mark D chip. I have successfully performed a stomp test prior to installing the chip but I am not able to perform it after installing the chip. It is a chip for a 173 ECU and I am running it in a 524 ECU. I have the newer style TPS so adjusting the throttle position switches is out of the question. I even removed the intake boot and manually and watched the throttle open completely as I was trying to coax the car into coughing up some information.
Do performance chips cause you to lose the on board diagnostic function? EDIT: NO THEY DONT, A BAD TPS DOES.
I will be testing my TPS tonight. What is that vac. line for on the TPS connector anyhow?
