Instrument cluster half-lit ......
  • Alex Mc
    • 281
    In my '88 M3..
    When i turn on the lights (parking or headlights), the cluster only lights up on the left side (fuel and speedo) while the right side does not. Also, the clock light on the OBC will go dim..
    -For what its worth, every once in a while the right side will light up.. at random.
    Any ideas?? Very frustrating.
    Current: Brilliantrot '91 318is M20B25
    Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
    wamchenry@gmail.com
    insta: @simple_machines
  • DEV0 E30
    • Oct 2004
    • 8853
    Have you tried twisting the knob clockwise? Have you tried hitting the cluster? (Mine has a loose wire, goes away after I hit it)
    • Alex Mc
      • 281
      Yes, rapping on the cluster did work for about two weeks, but it no longer fixes the problem. Something is loose, and I imagine someone has had the same issue - perhaps the solders somewhere? Just looking for as much input as possible before i take it apart..
      Alex
      wamchenry@gmail.com
      • Jordan
        • 12911
        Where the bulb to light the right side of the cluster connects to the main board is loose. Very common. 2 5watt wedge bulbs light the cluster, one for each side.
        https://mtechniqueabs.com/
        • Alex Mc
          • 281
          Thanks Jordan, perhaps the OBC light will be cured as well.. i'll try tomorrow.
          wamchenry@gmail.com
          • jht3
            • 288
            Re: Instrument cluster half-lit ......
            Originally posted by Alex Mc
            In my '88 M3..
            yep, same problem here in my 88 m3. right 1/2 and OBC is out 99% of the time. the OBC is tied to the right 1/2 apparently. i've pulled the cluster and swapped bulbs. doesn't fix it. i've been meaning to pull the cluster again, tear it apart and see if there's an internal problem or some way i can fix it
            James
            '88 M3
            • Alex Mc
              • 281
              This is what makes me think its a cracked solder on the PC board somewhere..
              wamchenry@gmail.com
              • e30Matt
                • 5077
                Just a thought, but isn't the OBC light supposed to dim when you turn the headlights on? It does in my '87 325is.
                • jht3
                  • 288
                  yes, but when the right 1/2 of the cluster doesn't light up the OBC backlight dies
                  that's my hunch too. when i get the time i'm going to take a real close look at the board and touch up the solder joints. i've also lost the left blinker indicator in my cluster
                  James
                  '88 M3
                  • Nathan
                    • Apr 2004
                    • 671
                    Just check all the bulbs. They do go out. They are really cheap to replace and more likely than not its the bulbs. But if you OBC goes out too then its probably some bad connection somewhere
                    PNW E30 CREW ///
                    • reelizmpro
                      • 9476
                      Yup or a burned track on the PCB which is also somewhat common. Just look for discoloration and check with multimeter.
                      88 M3 - LACHSSILBER/SCHWARZE
                      • Alex Mc
                        • 281
                        Turned out to be a gap somewhere in the circuit, but i was unable to pinpoint its exact location. To fix it, i simply jumped the right side to the left.. no sweat, and a permanent solution.
                        :D
                        wamchenry@gmail.com
                        • f u z z
                          • 1600
                          happens to mine, i just kit my horn and it goes on.
                          • jht3
                            • 288
                            :D
                            nice fix. this is what i did to my light switch as i didn't have any night illumination due to the dimmer rheostat being blown.
                            James
                            '88 M3
                            • jht3
                              • 288
                              ok, i yanked the instrument cluster and disassembled it on my desk. i started poking around with my multimeter and found what i think are two hairline cracks on the board. if you're staring at the cluster the breaks in identical spots on opposite sides of the board, right by screws hold the cluster together. the affected items are the left turn indicator and right 1/2 lights. see the attached picture, i circles the affected parts in red. the traces for these are the outermost ones on the board.
                              is there a way to repair this? i don't know anything about fixing traces
                              James
                              '88 M3
