If you're certain there's a dead segment, then you could follow the segment to the affected lights/whatever and run a wire to bypass it. That's all i did. Keep in mind, you often can't even see the crack in the PCB!
Instrument cluster half-lit ......
Current: Brilliantrot '91 318is M20B25
Former: '88 M3 3.2L, '91 318is 2.0L, '90 318i, '85 325e 2.8L, '84 318i 2.0L, '84 318i, '90 325is
wamchenry@gmail.com
insta: @simple_machines -
I know this is an old thread but I’m having this same problem with the car I just bought. The right side is my cluster doesn’t light up and my left blinker indicator doesn’t light up. I have the cluster out and I took it apart. Can anybody lead me in the right direction?Re: Instrument cluster half-lit ......
yep, same problem here in my 88 m3. right 1/2 and OBC is out 99% of the time. the OBC is tied to the right 1/2 apparently. i've pulled the cluster and swapped bulbs. doesn't fix it. i've been meaning to pull the cluster again, tear it apart and see if there's an internal problem or some way i can fix itComment
Send your cluster to Bavarian Restoration. bavrest.com
Most of the cluster on my Touring was not working when I got it. Bav Rest restored it and it's been working perfectly ever since.1992 325i Cabrio
1988 320i Touring
2000 M5
1977 530i
2015 328i - Euro Delivery/Performance Center Delivery
BMWCCA
E30CCAComment
