speedometer not working
  • Imagine_M
    • Nov 2009
    • 126
    I just fixed mine it was a broken solder on the speedometer in the dash had to pull apart the cluster and remove the unit and wiggled it until I found the wire that grounds from one corner to the other was broken, so I soldered it back and it worked right away.
    I also was able to get it to work from banging on the dash before I fixed it.
    1986 RED ROSE (325es)
    • Heysüß
      • 911
      yeah the only reason I think it's the sensor is because the obc avg mph also went out, so it seems to make more sense that it's the sensor at the diff.
      but thanks again r3v for the awesome info.
      09/1989 325i 4 Door
      +M30 Swap
      +Z3 Steering Rack
      • TeXJ
        • 1914
        my speedo works but my tach doesnt...could this be the same?
        1990 325is
        m52b28
        3.73lsd
        g260 (1987 325is 5spd tranny)
          • 34844
          no, the tach gets it's signal directly from the motronic computer.
          • TeXJ
            • 1914
            so what does that mean?
            1990 325is
            m52b28
            3.73lsd
            • Heysüß
              • 911
              well i'm a perma-noob so... is this the one? looks the same as the ebay ad one and not much cheaper.
              http://www.pelicanparts.com/cgi-bin/...FILTER_BMWM=ON
              is there a cheaper place?
              09/1989 325i 4 Door
              +M30 Swap
              +Z3 Steering Rack
