Pedal Box Removal in Airbag Car
  • Dirty e30
    • Sep 2009
    • 39
    The bracket that holds the master cylinder on my clutch broke a few days ago.
    I spent about half of yesterday upside-down underneath my dash trying to get the pedal box out, but it looks like the only way to do it is to drop the steering column, which sounds like a PITA.
    Is there a write up on how to remove the pedal box? I looked on every forum and checked out a bunch of auto to 5sp swap write ups, but found nothing.
    I managed to MIG weld the bracket while it was in the car (stupid, I know) but I'm not confident about how long it's going to last and want a more permanent fix.
    -Mike
    • 34839
    you don't. I mean, not unless you have to. You'll have to tear apart 90% of the dash to get to it, and break the sheer bolts that hold it to the column. People doing 5 speed swaps on airbag cars are (hopefully) swapping pedals and leaving the bracket alone.
    must have been some rust down there?
    • StereoInstaller1
      GAS
      • 22679
      Use a dremel on those shear bolts...cut a slot, then use a screwdriver to remove them.
      Closing SOON!
      Thanks for 10 years of fun!
      • Dirty e30
        • Sep 2009
        • 39
        There wasn't any rust (from what I could see). I have a pucked clutch, so maybe that added more stress?
        I was going to swap boxes for a non-airbag one, but the one out of my friends part car was starting to crack as well.
        I'll just leave it in there for now haha. thanks!
        -Mike
        • Jean
          • 18228
          Dude, buy a new one IIRC they are under $50 :) 35111157719 non airbag or 35111157720 airbag . Hit up blunt on the forum
          • Dirty e30
            • Sep 2009
            • 39
            If Luke's plan will make the pedal box removal easy, I'll do that for sure.
            Wouldn't mind a little peace of mind haha
            -Mike
            • rede30
              • 4697
              Can you get away with this? Does the automatic,airbag pedal box have the tab to hold the clutch return spring? I have done many swaps but I have always done it in non airbag cars and if I use airbag brackets they are from 5spd cars (and I make sure to cut off the extra length so it is the size of a non airbag bracket)
                • 34839
                there is no clutch return spring on airbag cars (you don't really need it anyway, the PP will push the clutch back by itself, or use a smaller spring hooked up somewhere). everything about automatic and manual pedal boxes in airbag cars is 100% the same, only the pedals are different.
                • StereoInstaller1
                  GAS
                  • 22679
                  Use the cutting wheels. It is easy stuff, and very little torque to remove the screws.
                  Give it a shot. I was surprised how easy it was, after trying for quite some time to get them off with vise grips.
                  Closing SOON!
                  • dollarbill425
                    • 34
                    Not to bring up old posts but, am I correct that the only way to install a 5 speed in an airbag car is to keep the stock pedal cluster and just add the pedals and fab a clutch ear for the spring or make something work like a spring or something? Besides buying a airbag 5 speed steering wheel... I didn't know this and now the last thing to put in my car is the cluster and the master and slave,
                    • whodwho
                      • Jun 2008
                      • 1547
                      Don't know it is the only way but definitely the easiest way and you don't need the spring Assembly.
                      My M20 Frankenbuild(s)
                      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                        • 34839
                        you don't need to fab anything. get a set of airbag pedals and bolt them in. airbag cars don't have that giant spring.
                        • CabbE30
                          • Aug 2009
                          • 2358
                          Bump!
                          I need help removing the sheer bolts. I cut a slot but the screwdriver isn't turning it. It's pretty tight.
                          • davem
                            • Jun 2010
                            • 705
                            Originally posted by CabbE30
                            Bump!
                            I used a stone bit on a cheap $20 dremel/rotary tool. Makes a lot of sparks and it's not exactly a quick way of doing it but it worked - the rotary tool can fit in that tight space.
                            • CabbE30
                              • Aug 2009
                              • 2358
                              ^^You cut the heads off, extracted, & replaced them with regular bolts?
