Speed Governor
This topic is closed.
  • Axxe
    • Aug 2004
    • 3355
    Speed Governor
    Did E30's come with speed governors? My car has one, 206 kph according to speedo. Two weeks ago I could go faster, but it was after a fresh ECU reset. WTF is going on?
    Keep it slideways!!
  • Mike 91 318ic
    • Jun 2004
    • 429
    afaik no they don't and PLEASE don't drive that fast. You will kill yourself or someone else and you will lose your license if you get caught.
    M
    • permit
      • Mar 2005
      • 3363
      well they have r3v limiters, which would limit your speed at top gear.
      • kowalski
        • Jan 2005
        • 1791
        Re: Speed Governor
        they do have govenors but the after market chips remove them. duno why you would be able to go faster after a fresh ecu reset, problably somthing to do with relearing the chip... i duno.
        • Old_School_Bimmer
          • Aug 2004
          • 38
          ya isnt the top speed 183 km/h i hit that an my car wouldnt go any faster. would but a chip increase top speed??? what model is ur car?
          • Axxe
            • Aug 2004
            • 3355
            87 325i. I was only going that fast because there were 3 or 4 cars going together in a chain last night at 4 am. No body else on the road. It's really annoying, I had another 1200 rpms left to go, and it just cut power.
            Keep it slideways!!
            • kowalski
              • Jan 2005
              • 1791
              my top speed before chip was like 220 or so on a 318is (91) and after chiop is whatever speed it is when it hits the redline, havn't tried it and i doubt im going to. too many tickets no more speeding for me:( the chips remove the govenor. and the only limiting things is the rev limiter.
                • 34844
                Re: Speed Governor
                no no no no no. No E30s came with speed governors. the only speed governor on an E30 is the brick shaped body which isn't especially aerodynamic. my car is "limited" to ~125mph, it just doesn't have the power to overcome aerodynamic drag.
                • kowalski
                  • Jan 2005
                  • 1791
                  no no no my car had a speed limiter because it stopped at that speed, iv had it higher since the chip and the fact that the chip says it removes the speed limiter and raises the rev limiter.
                  • Mike 91 318ic
                    • Jun 2004
                    • 429
                    what chip company said it removed the speed limiter? there isn't a speed limiter, Nando is right. Obviously there is a rev limiter, and the chip doesn't remove that either, it just changes the limit.
                      • 34844
                      and it stopped at that speed because of the brick shape of the car and lack of power to overcome wind resistance, not because of the chip. And I'm sure since you bought a $25 ebay chip that whatever claims they made about it's performance and abilities are 100% accurate.
                      the chip should give you more power, so of course you would be able to go slightly faster. don't forget to take into account things like windspeed and direction, the road you are on (hills and whatnot), etc.
                      I have a chip in my car and the top speed is exactly the same. it just doesn't have enough power to go any faster, unless I were to drive at 125+ for 5-10 miles. then I might break 128mph...
                      • Axxe
                        • Aug 2004
                        • 3355
                        It's definately a speed governor. It kicks in at the exact same speed going uphill, downhill, or on flat. It's still pulling and I can feel it "lift" and it sounds like hitting the rev limiter, bounces up and down. It feels the same as an E46.
                        Keep it slideways!!
                        • kowalski
                          • Jan 2005
                          • 1791
                          it was a 40$ ebay chip:) and i know it doesnt eliminate the rev limiter i didn't say it did.
                          quoted
                          Average of independent magazine sources. US residents, multiply by 1.2 if you want to convert an Imperial mpg result into US mpg. **Famously timed by Autocar at 162 mph with European 155-mph speed-limiter obviously inoperative! http://web.ask.com/redir?u=http%3A%2...amp;Complete=1
                          and here http://www.motocom.com/automobiles/1975/5/317
                          they say it has one and so did car and driver.:)
                            • 34844
                            E30s can't go 155mph. there is no governor, you can argue until your face is blue but it's not going to be true. also, the fact that you bought your chip on ebay pretty much proves my point..
                            • kowalski
                              • Jan 2005
                              • 1791
                              haha whatever i dont care enough to keep arguing.
