different fuel injectors on a stock e30?
  • chuckybob
    • Aug 2004
    • 952
    what're the effects of using non-stock fuel injectors with a higher pound/hour output on an otherwise stock car? are fuel injectors transferable through all e30s? are there any negatives other then running rich and worse gas mileage?
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
  • Jordan
    • 12916
    Re: different fuel injectors on a stock e30?
    Originally posted by chuckybob
    what're the effects of using non-stock fuel injectors on an otherwise stock car?
    More fuel wasted. Otherwise not much.
    No.
    Pointless on a stock motor.
    https://mtechniqueabs.com/
      • 37833
      Ya, they're just going to rape your gas milage
      Grover Beach, California
      BimmerHeads.com
      • erik325i
        • Jan 2005
        • 3567
        Would it help if you got bigger injectors along with an m30 afm? or would you still not recomend it?
        How would it be with just the m30 afm and stock injectors?
        • Jordan
          • 12916
          Pointless.
            • 37833
            Injectors and a M30 AFM will give you a slight improvment in power
            BimmerHeads.com
            • T.Dot E30
              • Mar 2004
              • 536
              What about with a chip also?
                • 37833
                Even better of course
                BimmerHeads.com
                  • 34844
                  FWIW I get slightly better gas mileage with my 19# injectors on a stock motor (except for an SS exhaust and chip).
                  • erik325i
                    • Jan 2005
                    • 3567
                    to what degree of modding would you say should be done before getting larger injectors?
                    • T.Dot E30
                      • Mar 2004
                      • 536
                      to what degree of modding would you should be done before getting larger injectors?
                      The technical answer would be, to the degree that your current injectors max out and cannot provide your engine with enough fuel causing it to run lean.
                      I forgot the exact number but i think it was ~178hp that stock injectors start to max out.
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        I'd say almost any worthwhile mod will max out your stock injectors. With just a chip I did.
