s14 itb's on m42
  • nickmp0wer
    • 1427
    s14 itb's on m42
    Ok so im pretty convinced i can make them fit physicly with my welder and adapter paltes. But could i use the m42 injectors in the s14 throttle bodies? if not i was thinking of either going with custom manegment, or just putting the throttle body ass. onto the adaptor that holds the stock m42 injectors and goes between the cylinder head and the intake manifold stock, what do u guys think?
  • Jordan
    • 12916
    It's a m42... spend the money to swap it, not to try and bastardize it.
    https://mtechniqueabs.com/
    • Stu Mc
      • 4083
      Good luck. S14 throttles are not the ones to use though. :)
      • nickmp0wer
        • 1427
        if i can get them for $50 (w/o airbox and trumpets) they are
        check these out http://bimmerforums.com/forum/showth...hlight=itb+m42
        • Stu Mc
          • 4083
          I see a hackjob setup that's not bolted on a motor....that is worthless. You gotta understand that the cylinder spacing difference between the M42 and S14 for all 4 cylinders, is roughly 3 inches. That throttle system doesn't look like it will even line up on an M42 head. I'd like to see more than one or two pics of the trumpet/port connection. S50 throttles are the ones to use, since M/S50's and M42's use the same cylinder spacing...hell the blocks are made with the same tooling.
          At any rate, if you decide to go the S14 route--best of luck getting it setup and tuned
          • nickmp0wer
            • 1427
            jez i thought the difference was like less then an inch not 3! I guess i'll looking to some euro s50 tb's but could i use the stock injectors? if not it looks like a setup like this might be the way to go and just leave the fuel rail where it is and have something like this before it
            • Jon325i
              • 6934
              Try $450 shipped according to the thread, and its still going to be a hack-job intake when you're done with zero guarantees that it will work. You can spend that $450 in a better way. 2 or 3 high performance driving courses is where I would put that money.
              Jon
              Rides...
              1991 325i - sold :(
              2004 2WD Frontier King Cab
              RIP #17 Jules Bianchi
              • Jordan
                • 12916
                Everytime I see that picture I just can't get over how rotted the thermostat housing is.
                • nickmp0wer
                  • 1427
                  Jon
                  i was talking about buying a different set and moding them myself. Theres a set of e30 m3 euro tbs on ebay right now
                  • Stu Mc
                    • 4083
                    If you need a set, we have some S14 throttles avail for sale I believe, I'll have to check with my brother.
                    • 2002maniac
                      • 4260
                      S14 Throttle bodies would be WAY too big for a M42. what you want is a 38-40mm TB. I have a ITB'd m42 planned for the future in an 02. I will be using a set of TB's off a Suzuki GSX 600. They are 38mm. If you go too big you will lose low end torque and there wont be any gain at high rpms when compared to properly sized intakes. Megasquirt and some hairy cams would make for one FUN m42!
                      • Streetspec_iS
                        • 1622
                        yep, i was going to say look into using bike throttles. usually found in abundance and it is easier to adapt them. the good thing is they come as a 'complete' unit (ie fule rail, injectors, TPS...). a lot of them are attached with silicon hose, so all you need is an adapter plate w/ runners to suit the mb tb set spacing. tie that in with some after market management and ya laughing.
                        and yes, i am one to agree. especially in a lightweight '02. keep us posted.
                        sigpicM42 Brigade ... Throwing craze in the 318
                        • Streetspec_iS
                          • 1622
                          your other option would be to mak/have made a custom larger intake plenum, and run a single(or double) larger TB on the intake of it.
                          • nickmp0wer
                            • 1427
                            yeah i looked at some of those on ebay and they look like they'd work quite well. It looks like they have 2 throttle plates in each tb for a progressive rate throttle which is similar to what the stock tb is like.
                            http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
                            seems like it would be pretty easy to attach these before the stock fuel rail. I think the hardest part would be making an airbox
                            • 2002maniac
                              • 4260
                              I wouldnt bother with an airbox. Just use sock filters on the velocity stacks. You would need Megasquirt, SMT-6, or some other standalone, but you would want that anyway
