getreg refresh?
  • Zues
    • 145
    getreg refresh?
    Hello gentlemen. I am now the proud owner of a getreg 260 and am curious about refreshing the old girl a bit. Beyond replacing font and rear seal and short of a full rebuild, what would be a good idea to look at.
    90 m20is
  • Dj Buttchug
    • Jun 2010
    • 7654
    change the fluid.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Zues
      • 145
      Got the fluid
      90 m20is
      • TrentW
        • 2815
        Interested in this in the near future also.
        • jasonsnoddy
          • 1900
          Step 1: Got the fluid.
          Step 2: Change the fluid.
          Step 3: ???????????????????
          Step 4: PROFIT
          Originally posted by stewie30luvr
          ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
          Originally posted by JakeP
          with a coathanger
          • briansjacobs
            • 1278
            witht the price of E36 M3 gear box's so cheap and the lack of availability of 260 parts (on the cheap) if I had to do it over again I would have done the E36 swap and dealt with the crooked shifter and saved a ton of money. Granted I did have my 260 done by Blanton who is twice as expensive as anyone else, but wow it is silk now.
            Brian Jacobs
            • Zues
              • 145
              I've spent$ 90 on my entire swap and all i need is am mc, so i figured i would put a little$ in the box
              90 m20is
              • kishg
                • Sep 2006
                • 2624
                get a fresh rebuild from drivegear.
                '12 F30 328i Sport Line
                '91 SpecE30 #523
                '00 Ford F-350 Dually Tow Vehicle
                BMWCCA #360858 NASA #
                128290
                • Zues
                  • 145
                  whats the cost on something like that.
                  90 m20is
                  • Zues
                    • 145
                    bump for more options.
                    90 m20is
                    • Mossman
                      • Apr 2006
                      • 1961
                      Just replace all shifter parts, as long as there isn't something seriously wrong inside the box you'll be fine. If there is it pays to get a different one rather than fix yours, or spend $600 for a rebuild from the guy that got mentioned a couple posts up.
                      Front seal, rear seal, shifter rod seal*not mentioned but you should do*.
                      Then new shift rod, front knuckle thing, some yellow washers, and a shift lever to taste (z3, Mcoupe, z4, e36 m3 , whatever floats your boat)
                      • Zues
                        • 145
                        Cool im going to ty and crack it open and check out the gears
                        90 m20is
                        • MoparJ
                          • May 2007
                          • 258
                          Not to threadjack, but does anyone know where to buy (other than the dealer) the tube that the throwout bearing rides on? My tranny's out of the car, and I noticed that part has some noticeable wear. Pelican recommends changing it in the write-up on their site, but they don't seem to sell them.
                          Jason
