Stumped...Car won't start
  • Jordan
    • 12916
    guys its not the fuel pump, coil etc.
    All that shit works fine.
    They are not being switched on by the ECU.
    https://mtechniqueabs.com/
    • Nathan
      • Apr 2004
      • 671
      still need help...
      PNW E30 CREW ///
      • Bimmerfanatik
        • May 2004
        • 5349
        Two things: did you check/replace the relay right next to the ECU?
        Second, is there a kill switch on the car you might not know about? Hazard switch, left blinker, etc? I had this SAME problem ona subaru of mine. Replaced plugs, wires, ignition coil. Still nothing. Sat in the car getting frustrated. started pushing buttons, hazard switch, tried it again, it worked.
        Worth a shot...
        • Brew
          • 3060
          Originally posted by Nathan
          still need help...
          Check to make sure that there is power and ground at the ecu.
          I'm willing to bet that's your problem.
          '91 318is
          • thumper3ld
            • Apr 2005
            • 84
            I had this problem too and just got it fixed. My issue was the fuel pump relay. Atleast thats what it was according to my mechanic.
            • DarkWing6
              • Apr 2004
              • 7144
              Not that.
              Ok, tonytony is willing to drive up and swap ecus with me. The only thing is that his is a 524 and mine is a 173. Will this still work? If not is there anyone near Vancouver, WA that is willing to drive and swap with me? Lunch, dinner, gas $$? Please?
              • Brew
                • 3060
                Yeah, it will work.
                '91 318is
                • DarkWing6
                  • Apr 2004
                  • 7144
                  Ooops, last 2 post belong in my car wont start thread.
                  • Joey Link
                    drunkest guy at Oktoberfest!
                    • Nov 2004
                    • 1176
                    What was this? I'm having a very similar problem.
                    • Addissimo
                      • Mar 2004
                      • 1820
                      check and make sure you're getting switched 12v at your main relay. If you're not, check the wires underneath your steering column, there is a big cluster of them that can cause problems(in my car at least).
                      -Addis
                      Doing something M50 related? -> http://www.addissimo.com
                      On Myspace? ->http://groups.myspace.com/r3vlimited
                      BF2142 SN = BillyGoose
