Stumped...Car won't start
  • Nathan
    • Apr 2004
    • 671
    Help!
    I am completely stumped. yesterday morning i go to start my car and all it will do is crank. Today i investigate the problem and i find out that the fuel pump and the spark plugs aren't starting up which means the ECU isn't starting them becuase some sensor is bad or giving it bad info. So, look toward the reference sensor for the flywheel and the crank speed sensor. I test those and they are within the ohms range. I have heard of the pin on the flywheel that the reference senser uses falling off so i check for that...pin is there. I reset my ECU...no go there either. All fuses are great. My fuel pumps all work; i jumped the relay and made sure of it. After all of this i am still left with a car that goes no where and 80 miles from school tomorrow... I need some help, and soon. What other things cuase this problem?
    Thanks
    PNW E30 CREW ///
  • freddie21
    • Apr 2005
    • 5
    same happened to me 2-3 months ago. ECU was dead. no visible sign of failure, no reason for it to fail, just did!
    • Nathan
      • Apr 2004
      • 671
      Anyone else have this happen? Anyone know of a way that i can test for this. Anyone got a compatable (85 325e) ECU they want to sell?
      PNW E30 CREW ///
      • Nathan
        • Apr 2004
        • 671
        well i'm going to try swapping the ECU and see what that does, still taking advice though.
        PNW E30 CREW ///
        • chuckybob
          • Aug 2004
          • 952
          check the O2 sensor, maybe?
          : : 1984 318i : : PNW E30 Crew : : Sold!!
          Now becoming the R3vlimited Pro3 car
          http://www.r3vlimited.com/board/showthread.php?t=93780
          • Jordan
            • 12912
            You don't know anything about cars do you.
            https://mtechniqueabs.com/
            • Bimmerfanatik
              • May 2004
              • 5349
              hehe, though a bit mean, admittedly very funny :)
              It's nice to try and help people on the board, but if you really don't know...let someone who does answer. You don't have to post an answer to every question, you know... :)
              • DEV0 E30
                • Oct 2004
                • 8871
                My O2 sensor's wire has been cut since before I bought the thing. (car)
                I had this problem for awhile. I don't know why still. Maybe try disconnecting the battery, to make the ecu forget stuff? It could be the same intermittent problem I had... sorta just went away.
                • Nathan
                  • Apr 2004
                  • 671
                  I know my first post was big but please read the whole thing if you are gonning to try and help...
                  PNW E30 CREW ///
                  • gstuning
                    • 833
                    Definitly ecu relay or the ECU
                    swap some relays around to see if anything else stops working or the cars starts working,
                    if not ,, it´s the ecu
                    should be cheap anywhere close at the nearest bmw parts yard,
                    or just post a WTB
                    Gunni
                    @ Prodrive / Aston Martin Racing
                    • Jordan
                      • 12912
                      ECU was just swapped for a known good working 027 ECU. Still no start.
                      • BavarianBimmer
                        • 951
                        receive the coil tension ?
                        Fuel pump ?
                        Is there tension on the injectors ?
                        1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                        1997 E36 328iT
                        1990 E30 325iT 24v SOLD
                        1989 E30 325i 2.7i M-Technic II SOLD
                        • NickP
                          • 257
                          Do the rpm's move at all when you're trying to turn it over?
                          • Nathan
                            • Apr 2004
                            • 671
                            nope
                            PNW E30 CREW ///
                              • 34839
                              how about your coil?
