Brake Lining light on
  • Afredo
    • 349
    Anyone know what would cause this light to be on on the instrument cluster? Brakes work fine. The rear passenger brake pad sensor connector is broke and does need replacing, would that cause this? Thanks!
    "Once more into the fray."
  • archie
    • 5448
    I would think that's the problem or you better hope. Cuz it's a bitch to figure out if it aint.
    I'm dealing with this issue at the moment also.
    88 M3 Diamantschwarz
    89 M3 Zinnoberrot
    56 Isetta
    LIKE ARCHIE'S on Facebook!
    • Cabriolet
      • 9620
      sometimes if you leave the sensor unplugged water can get into and send and signal back to the dash. (happened on my ES all the time)
      if not that, if the sensor is mangled it could be shorting out.
      Much wow
      I hate 4 doors
      • Afredo
        • 349
        I don't even think theres a sensor hooked up to the rear passenger wheel connector cuz its broken. I'm going to get the parts soon and install them, hopefully that turns the light off.
        • magat1
          • 4
          mine was on and was missing the sensor wire on in the rear passenger side and I just put a piece of wire to short it out and light went off.
          • mikeedler
            • 6707
            mine flashes on once in a while-- I am just gonna yank the stupid ass bulb out.
            if the sensor is bad, then yes, that is the problem- once the circuit is broken, the light will light up.
            there is another light in the dash for other brake related problems.
            • StereoInstaller1
              GAS
              • 22679
              Guys, if it is unplugged, it is "open".
              When the system sees open, it triggers the indicator.
              How to (most of the time) FIX it: Buy new sensors.
              Before you put your new sensors in, scrub the connector with CRC electronics cleaner and a pipe cleaner, get those connections as clean as you can. Put a dab of dielectric grease (same shit as spark plugs get) or just plain old vaseline inside the socket before you plug them together.
              This $20 fix generally fixes all the issues.
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • mRodiek
                • 597
                My light just went on damn...theres also a clunking when I go over pumps from the right rear passenger wheel though.
                Originally posted by e30lov
                sweet a mk4 jetta, haven't seen one of them for about 14 seconds
                Adventures of an E30
                • quikveedb2
                  • Sep 2007
                  • 2258
                  clunking = shock mounts
                  You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
