My 1988 325ix has been having lots of over heating problems lately so here the story. As long as I'm drive and doesn't have to be real fast ill be fine but if I'm stopped or letting the car warm up it will overheat. the p/o replaced the fan clutch so i don't think its that but its a possibility. and i've replaced the w/p and thermostat also so that's not the problem. But i can't get it to bleed the air pocket out. ill let it warm up and heater on and on a hill and when i crack the bleeder air comes out and some fluid but tons and tons of air and it just keeps coming till it starts want to over heat so i shut it off and it does the same thing but as im bleeding it, the fluid in the over fill tank never goes down at all not even a drop unless i shut the car down and open the cap then it sucks it down. but then just more air out of the bleeder screw. so i was thinking maybe its the reservoir tank cap but the over fill works and anti-freeze comes out from the corner of the fender. If i feel the bottom left corner of the rad(driver side) its barely warm when the top is hot like it should so possibly plugged but that would make it not bleed and it never leaks. its like its pulling air in some where. Kinda makes me think the head gasket but its coolant and oil are not mixing and I'm not blowing white smoke.
Any help or suggestions would be really nice because winters coming and i have to get the 944 in storage and off the road soon.
thanks so much, Stevan
