F**K i need serious help quick
  • u3b3rg33k
    • Jan 2010
    • 2452
    Originally posted by lolcantturn
    and then I pondered up some great idea and got it out. bilsteins rock.
    Thanks for all the help!
    details or ban.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
    • george graves
      • 20003
      Gayest ending ever.
      Originally posted by Matt-B
      • lolcantturn
        • 4588
        Gayest ending ever.
        the fuck did you expect?
        more liquid wrench, a hammer to break rust, a drill, JB weld, and water pump pliers saved the day.
        Originally posted by TSI
        OEM+
        • george graves
          • 20003
          I fucking expected you to tell us how you magically got the bolt out, Merlin.
          • Adrian_Visser
            • Jun 2006
            • 2823
            I'm almost afraid to ask... Where was the JB weld used?
            '89 Alpine S52 with goodies
            • george graves
              • 20003
              ^see. I'm not alone.
              • accident
                • 7303
                also curious
                Moral of this story?
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  Perhaps he sucked it out, and didn't want us to know.
                  • McGyver
                    • 4636
                    made a new bolt end to repair the broken one. duuuh!
                    • lolcantturn
                      • 4588
                      hammered the bolt to loosen the rust, liquid wrench, hammered again, and liquid wrenched again. waiting a couple of minutes. Took a nail and hammered an imprint onto the bolt. Drilled a small hole, jb weld a weird piece I found in my basement. Lefty Loosey, and it moved a little before the JB weld stopped working because it didn't cure all the way. Took a water pump plier now that the bolt was out enough to grab it just a little. Put vice grips tightened with another water pump plier onto the water pump plier holding the bolt so that it's on there super tight. rotated and bam, came out. Super ghetto I know.
                      I assume the bolt was only just reallllllllllly weak at that point, because it wasn't torqued down as tight as I thought.
                      OEM+
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        So how many pairs of vice grips and water pump pliers did you use exactly?
                        • george graves
                          • 20003
                          I'm going to need pictures, a video, and a 3d diagram.
                          • jasonsnoddy
                            • 1900
                            This thread just got much better.
                            Originally posted by stewie30luvr
                            ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                            Originally posted by JakeP
                            with a coathanger
                            • b*saint
                              • 3794
                              See the way I would've done it is heated up the boss cherry red to it expanded away from the bolt. Then took my air hammer and pointed chisel and walked it loose.
                              Ma che cazzo state dicendo? :|
                              • ClassicSkril
                                • 49
                                pictures would have been nice. sounds like you jimmy rigged the hell out of it, but if it worked more power to you. you should have taken pics of your process to add value to this thread.
