Comin back from I-80
My car is starting to make some funky ass noise from the engine bay.
I pull over to a gas station, and I hear waht Resembles rod knock, but it is not so harsh. at Higher RPMS it is almost faint. Anyway, IDling it was making the noise, and I realized Im FUCKED if I get it towed, so I drive the 2 miles up the freeway to davis, and im trying not to freak out from the noise.
anyway, I pull into the parking lot, and it nearly goes away. I couldnt distinguish it from the top or bottom of the engine. but I took an audio file, If you can ignore the very loud rattling of the aluminum flywheel than you might be able to hear it.
If anyone has an Idea what It is, or should I start hunting for a new m42 for when I can finally afford to buy one.
To understand the urgency, I have a job in marin, that I have to commute to on thursday through Monday. and Im nearly done with the 2002, Im just assembling it.
Link:
wht would be the minimum I could pick up a m42 longblock for?
EDIT:
NEw findings:
here's how it sounds :(
here's what I found:
I dont know what that little thing is, but It was floating around once I pulled the valve cover
Link:
EDIT:
NEw findings:
